I have the opertunity to replace / update the machinery in my classroom. I currently have:
2 - 10" Delta Rockwell Table Saws
1 - 8" Delta Rockwell Jointer
1 - 18" x 6" Delta Rockwell planer
1 - 17" Rockwell Drill Press
1 - 10" Delta drill press
1 - 12" Dewalt sliding compound miter saw
2 - 20" delta varible speed scroll saws
2 - router tables
1 - 46" Rockwell lathe
1 - Grizzly osc. spindle sander
1 - Powermatic osc. edge sander
1 - 14" rockwell bandsaw
The machines that will be replaced / upgraded will be the following:
Table saws
Jointer
Planer
Lathe
Bandsaw
I have researched many different high school woodshops in my area of Michigan to see what types of machinery they have and to see what they are teaching. After much thought I will be replacing the table saws with the Saw Stop table saws. The lathe I would like to see 2 powermatic lathes with digital speed readout. I would also go Powermatic for the band saw. I am going to push for 2 bandsaws because the students use it so much. As for the jointer and planer, both of those machines are working just fine. However, I would like to replace the cutter heads with the helical cutter heads to cut down on the cost of replacing the blade sets (If the cost is close I may just replace the machines and not just the cutter head). I will also be adding the JDS Multi Router here is their site
My question to you guys....If you could put any piece of machinery in your old high school woodshop....what would it be?
Jeff
2 - router tables
Table saws
Jointer
Planer
Lathe
Bandsaw
Jeff
