Air Purifier
  • p8ntblr
    • 921
    • So Cal
    • Craftsman 22114
    Air Purifier
    My brother (and some other family members) live in Irvine somewhat close to where the fires are. Thankfully they were far enough from the fire itself but the air is still really bad. I was there Sunday when it started and the half the sky was covered with ash. I can only imagine how bad it is now. They've been looking for some air purifiers but most stores seem to be sold out.
    I have a Delta AP100 (the triangular one) that I got a while back during the Lowes clearance. Still sitting in the box. Do you think that would well enough for an entire home. It would probably be temporary till they could find a better one.
    http://www.amazon.com/Delta-AP100-Sh...3360956&sr=8-1
    -Paul
  • SHADOWFOX
    • 1232
    • IL, USA.
    • DELTA 36-675
    Glad to hear you guys are okay. The unit that you mentioned is an air filtration system which has a 5 micron filter. It might be too loud to use in the living room but you can always give it a shot.
    Chris
    • Hoakie
      • Feb 2007
      • 382
      • Iowa
      Several box fans with furnace filters attached may be a cheap alternative as well. I have one running in the shop and one in the family room to collect pet dust and pet debris . They pull a lot of air and are pretty quiet
      John
        • 8796
        What Hoakie said. Good alternative.
        Your Delta will work too. Remember in situations like this, even if it doesn't get below 5 microns, it will filter out larger bits. They will probably have to change filters often too.
        If it is unavoidable, anything is better than nothing at this point.
