My daughter has a '96 Buick Park Ave. - 3.8L. We bought it 2-3 years ago. It had 100,000 miles when we got it and currently has about 140,000. Only problem we have previously had is about 6-months ago I had to replace the upper-plastic intake manifold due to a water leak.
Per my daughter, at idle it started to have an intermittent oil pressure light come on. I told her to pull over immediately and I met her to look at the car. I first checked the oil (I just changed it a couple of months ago) and the level was fine. When I started it up I could hear a knock in the engine. Sounds louder from underneath the car especially at increased rpm's. I also verified that the oil pressure was low with the dash mounted gauge.
I changed the oil and removed/disassembled the oil filter. This is the first time I took apart a filter. It had black grit, some small shinny non-magnetic specs, an a couple of metal slivers (maybe 1/32" wide x 1/16"-1/8" long). I wasn't able to heat the car up totally but the oil pressure was around 20-30psi.
Tonight I thought to remove the injector wires one at a time to see which cylinder might be the culprit. The result was unexpected. When I removed one of the wires - the cylinder at the firewall closest to the accessories the noise increased by tenfold (maybe a little exagerrating).
Is this just a rod bearing? Can I get by with just changing the rod bearings? Looks like on this big Buick I can drop the pan and get at the bottom end w/o removing the engine. Due to age/miles don't want to put too many dollars into it.
Thanks,
Thanks,
