wiring 220
  • jussi
    • 2162
    wiring 220
    I'm curious into what's involved in wiring a garage for 220V? If I go hire an electrician what does he actually do and what type of hardware is involved?
    Also as I understand it the line from the electrical lines is already 220V and just gets reduced down to 110V. Is this correct. If so, where does this process take place. Is there a transformer in the poles or in the box in my house?
    No, that's not how it works. Your home actually has two separate 115V lines coming in (they are out of phase from one another). The things in your house requiring 230V are connected to both "hot" lines and the neutral, while the things requiring 115V are wired to only one of the "hot" lines or the other and the neutral. There are many other factors which should be considered when adding 230V, such as load and wire size, circuit breaker size, conduit routing, codes and permit requirements, and even whether your present service is adequate. It may be as simple as adding a double pole circuit breaker to your existing box, or it could be much more complicated. You are doing the right thing to hire an electrician. This is one job where you are better safe than sorry.
    • Jeffrey Schronce
      • 3822
      • York, PA, USA.
      • 22124
      UC is dead on with the detail and the suggestion. Definately want to get an electrician to run the sub panel from your current panel (assuming current panel and supply is sufficient).
      While no one will likely tell you how to DIY, your quesiton can be better answered if you give us a little more detail.
      How many amps is your current service at the main panel?
      Are you running to an attached or detached garage? How far from current box?
      What are your demands, ie how big does new box need to be?
      • Tom Slick
        • 2913
        • Paso Robles, Calif, USA.
        • sears BT3 clone
        to add a 220v circuit to your garage is simply a 220v breaker in the breaker box, then wire over to where the outlet is installed in your garage. as UC mentioned your house already has it, so it is simple for an electrician to hook it up for you.
        one caveat to UC's post is in a 220v circuit, typically there is 2 115v lines and a ground, no neutral. the neutral is added to the circuit if the appliance needs 220v and 110v from the same source.
          Every 220V circuit in my house has both a neutral and a ground (black/red or black/black, white, green). Maybe that's just the code around here, I don't know.
            One thing to think about. When you work with electricity, do you shut it off? If yes, then hire it done.
            The reason why, even thought the new leg to the outlet you run will be dead until you flip the breaker, there are live ones in the box. Nerves, distractions, and not having someone around with a broom to knock you back, means your better off with a licensed electrician.
            I wanted to swap out my box, and my electrician refused to do it, because he says I am very capable of it (he has seen me work). I do fear being in the can (where the power line comes into your house) and rewiring the main breaker (always a good idea to replace that line when installing a new box), so it hasn't been done.
            • Kristofor
              • 1331
              • Twin Cities, MN
              • Jet JTAS10 Cabinet Saw
              The 220 that was in my house when it was built (range (not used, it's gas), and dryer (electric for now)) are both 3+ground wire jobs with a 4 conductor recepticle.
              The 220 outlets I've added inside (table saw, jointer) and the welding circuit I added in the garage are 2+ ground. Now, I may kick myself if/when a new tool comes out that needs 220V for the motor and 110V for the built-in computer and internet connection but for now I'm okay.
                This is probably a pretty good assessment. I helped my electrician setup my
                *detached* garage for 220. I had to do some trenching but he made the
                connections from the subpanel to the main panel. After that, I did all the
                wiring in the garage myself. I've worked in the main panel and I didn't enjoy
                it at all. Working in the sub is a different story because A) I can shut off
                the power from the main and B) it's a lot less crowded in the sub and getting
                too close to something live isn't as easy. Although I read as much info as I
                could to install the sub myself, I sleep a lot better knowing a pro did the hard
                part.
                Paul
