i'd like to DIY changing my car's tranny fluid/filter.
from what i've seen on DIY sites, you can either drain the fluid at the pan, or you can disconnect one of the tranny cooling lines (and subsequently add more ATF which will get rid of the residual fluid).
any thoughts on the best way to perform an ATF change?
any tips, like using gasket sealer on the pan gasket?
