'Tis A Good Thing
    'Tis A Good Thing
    I don't make my living at this.
    What's wrong with the following code? Hint: It took a bit to find where the program was getting stuck. Then it took a bit to find where it was still getting stuck. On the plus side, IDEs are wonderful.
    While (inFileLines.Length < index )
    If (InStr(inFileLines(index), "kickstart") <> 0) Then
    Return"Cisco"
    'check for a brocade switch
    ElseIf (InStr(inFileLines(index), "Fabric OS") <> 0) Then
    Return"Brocade"
    End If
    End While
    'Tis a good thing? You won't get an argument from me. But you wouldn't if you said it was a bad thing either.
      I'll take a guess. If the string you're searching doesn't contain "kickstart" or "fabric os," the loop becomes endless.
      • gerti
        • 2233
        • Minnetonka, MN, USA.
        • BT3100 "Frankensaw"
        index++ or something like that missing...
