Visual Basic Help Needed
    If I have code in a subroutine thusly:
    Code:
    Dim aReadStream = IO.StreamReader
    [SIZE=2]aReadStream = IO.File.OpenText("c:\test.txt")[/SIZE]
    [SIZE=2]someSub(aReadStream)[/SIZE]
    Then I have someSub declared elsewhere defined like:
    Code:
    Public Sub someSub(ByVal aStream as IO.StreamReader)
    when someSub is called it will be passed a StreamReader object pointing to a file called test.txt, no? Or should I be passing it by reference? Asking because it does not appear that someSub is actually reading test.txt - I have this code in someSub:
    Code:
    aLine = aStream.ReadLine
    A logic statement I have is not working I think because aLine is showing up with no value in my Locals window. Do I need to pass it by reference instead?
  • Alex Franke
    • Feb 2007
    • 2641
    • Chapel Hill, NC
    Object references are passed by value. If you use byref, then the reference will be passed by reference. In any case you're working with only one instance of streamreader. (You'd pass byref, for example, if you wanted to set the original varuable to null/Nothing).
    So you're passing the streamreader by reference, and ReadLine() should read the first line of test.txt.
    I don't know how VB escapes characters in strings -- if you're running into a problem opening the file, you may need to escape the backslash: "c:\\test.txt"
    BTW, this applies to reference types (objects), not value types (int, bool, enums, structs, etc). The StreamReader is a reference type. But if you were using a value type, then byval would be making a copy of the variable and byref would be passing a reference to it. For a reference type, byval copies the value of the reference to the object, and byref is a reference to the reference to the object.
    • Alex Franke
      • Feb 2007
      • 2641
      • Chapel Hill, NC
      One last thing: Remember to dispose the streamreader by calling aReadStream.Close() or by putting it into a using block (if VB has that).
      • Hoakie
        • Feb 2007
        • 382
        • Iowa
        Agree with Alex on how the references are passed. VB does not escape paths and it does have the Using block (i am not a fan tho)
        This code compiles in VB.Net2005 and reads the first line of the file for me.
        Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Dim aReadStream As System.IO.StreamReader
        aReadStream.Close()
        aReadStream.Dispose()
        End Sub
        Private Sub someSub(ByVal reader As System.IO.StreamReader)
        Console.WriteLine(reader.ReadLine)
        End Sub
        John
        • Alex Franke
          • Feb 2007
          • 2641
          • Chapel Hill, NC
          Yeah, that looks perfect, Hoakie.
          crokett, you might also check to see if the file is empty or if the first line is blank. If it's empty, you'll get null/Nothing when you call ReadLine(). Usually you would use this to test for EOF like "while ((line = aReadStream.ReadLine()) != null) { /* Do something with line */ }" , but it might throw you off if you're not using it that way.
          Also, ReadLine() will stop at \r, \n, or \r\n (Windows and Linux handle and display EOL's differently), so even if your file looks like it has no lines in Windows, it might actually have some.... Just a thought...
          • Hoakie
            • Feb 2007
            • 382
            • Iowa
            I forgot... after looking up the .Close() method again, it handles the dispose so the .Dispose() call in my code is not necessary
            John
            • tedkitch
              • Jul 2006
              • 646
              • NE Suburbs, Chicago
              I've seen it all now. Programming help on a woodworking forum. The funny thing is if you post this to a VB forum, you will get about 10 different methods of doing this and multiple critiques of the code. You guys have given some of the most straightforward answers to a programming question I've ever seen.
              Kudos,
              Ted Kitch
                That's why I post the questions here Ted. I know we have some programmers here. I figured out the problem though.
                Here's the actual code from the subroutine.
                Code:
                [SIZE=2][COLOR=#0000ff]Do[/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff]Until[/COLOR][/SIZE][SIZE=2] ((inDataFile.Peek <> -1) [/SIZE][SIZE=2][COLOR=#0000ff]Or[/COLOR][/SIZE][SIZE=2] (InStr(strDataLine, strParseZone) > 0))[/SIZE]
                [SIZE=2][/SIZE]
                I pass the streamReader object in as inDataFile. strDataline is declared in the subroutine but it never gets set to a value. This is why I don't get paid to be a programmer.
                • Hoakie
                  • Feb 2007
                  • 382
                  • Iowa
                  Nah, Even paid programmers make mistakes too.
                  Glad you figured it out. either you won't do it again or it won't take nearly as long to figure out next time.
                  John
                  • Alex Franke
                    • Feb 2007
                    • 2641
                    • Chapel Hill, NC
                    They're not mistakes -- they're "success opportunities" for testers.
                    This part looks a little curious to me: "DoUntil ((inDataFile.Peek <> -1) Or (...))". If there's a "next" character in the file, then Peek() will return it as an int and so it won't be -1. So the first condition will be true, then the second condition will be skipped because of the Or, and you'll have your end condition and break out of the "DoUntil" loop.
                    • Hoakie
                      • Feb 2007
                      • 382
                      • Iowa
                      Actually, using the "OR" in VB is not short circuited. Both expressions ARE evaluated as written. VB recently got the AndAlso and OrElse features that gives it the long overdue short circuit capabilities. Previously you needed to use two IF statements.
                      John
