This morning I went out to see if I could push out a dent in the outside of my Tacoma bed right behind the fender. I am not real sure why I thought if I took off the side of the factory "bed liner" I could get to it as usually there is a hard metal surface under a liner called a truck bed.
Now if you notice I put bed liner in quotations, that's because it's not a bed liner, it's the actual bed. Most liners that I have seen line a metal bed, if you take out the liner there should be a nice painted shinny metal surface there. Not the case here.
I have a TRD with the electrical outlet in the back corner wall of the bed, which I first took off to see if I could get the rest of the "liner" off, when I noticed I could see the plastic wheel well liner. If you look up under the truck you can see the molded plastic instead of a metal bottom.
Normally I guess this wouldn't bother me so much, but the window sticker I saved clearly states bed liner on it.
Good news is due to Toyota's short comings I was able to reach up and pop the dent out, but if they are going to sell me a liner it better d@mn well line something!
If anyone is curious, they introduced these "liners" on the new body style Tacomas.
