Took Friday off, planned to get some shop time. Then I saw some water leakage onto the entry hall floor, and it soaked the coat closet carpet. Could only be from one source - the HVAC unit in its own closet right next to it. Yep. Blocked drainage tube. OK. No problem. Just clear it out.
Right. Should have been a friction fit but I couldn't get it loose. OK. Hook up the ShopVac to the drainage tube outside. Try to "suck" it clean. No dice.
2 hours later gave up. Called an air conditioner guy. He couldn't loosen the indoor connection either, but was able to get to the internal connection and blow it out (cool tool!). Then hooked his ShopVac to the outside and finally got it clear. Only got an hour in the shop.
OK. Saturday. Yard work done, decided the car hadn't been washed in months thanks to all the rain we've had. Cleaned and Armor All'ed the inside. Washed it good. Took it into the garage and gave it a good wax coat.
Now, shop time. Hit the garage door button. Door went half-way down, then ... BANG! I knew that sound. Disconnected the opener. Door slammed closed.
Yep. Busted spring. Waited an hour to get a guy out to replace both springs. Very interesting watching him do it. Still not sure I'd ever want to do it myself (too dangerous).
Only 2 hours shop time today. What a weekend!
OK. Now the question. The garage door guy said to lubricate the new springs every 3 months or so with motor oil. I'd been using WD40 which he said dried out too fast.
Motor oil sounds fine, but awful messy. I assume his advice is good, but any suggestions on just how to do that without making a real mess???
