There would be absolutely zero gravity anywhere inside the hollow sphere regardless of the thickness of the shell or your location inside the hollow. This assumes a spherical shell of material with a spherical hollow (think of a basketball).
If you are closer to one side it is true that the gravitational pull from mass on that side will be larger. However, there will be more total mass pulling you back from the other side. The net result is that there is zero net force anywhere inside the hollow.* **
* As an interesting side note, apparently Hitler and many of the higher up Nazis believed the earth was hollow and that they could escape capture by tunneling to the center of the earth. They believed they could live on the inner surface of the earth. Crazy stuff, I'm not making this up.
** This assumes a classical description of gravitational force (Newton's Universal Law of Gravity). Gravity is an inverse square force, meaning the force goes as 1/(r*r) where r is the distance between the objects. Since the surface element of a sphere goes as r*r, there is a balancing between the surface element and the inverse square force that results in zero gravitational force inside the hollow.
Oh, wait a minute -- we're talking physics here, not psychiatry...
j/k
