Taking down a Deck
    Taking down a Deck
    This weekend will be tearing out the old deck. I finally got tired of piece-patching. Been wanting to do this for two years. Want it to be efficient yet satisfying. I do not plan on saving any of it. So... I've decided my sledge hammer will be involved. After that, the usual shop tools or is my chainsaw overkill?
    Mornig Crockett...
    Probably over-kill on the deck. I just got through doing it with a wrecking bar and a reciprocating saw which is safer and gets in nooks and crannies a lot easier... I had it down and sized for the city to pick up and on the street in less than an hour. If your deck is made from standard size lumber ( I have a neighbor that built a gaint one with 6 x 6 and 2 x 12 stock, the "re-cip" would be a better and safer fit IMO!
    Regards...
    • TheRic
      • Jun 2004
      • 1912
      • West Central Ohio
      I think the chainsaw might be more fun!
      Ric
      • Tequila
        • 684
        • King of Prussia, PA, USA.
        If you're tearing it completely down, the chainsaw will be fastest, but you've got to be very careful of nails & screws since they can go flying off a chainsaw.
        If you're just replacing the boards, I'd go with the recip. That will make it a lot less likely that you'll damage the joists in the process.
        I'm tearing out a deck next weekend, and I'll be using a recip, if that answers your question.
        -Joe
        • Stan
          • 966
          • Kalispell, MT, USA.
          • BT3100, Delta 36-717
          I'm thinking a truck with a snatch-em strap. Once you get the whole thing pulled away from the house -- go slow for a little ways (limit the demolition).
          Then once your a few blocks from the house -- drop the hammer and you'll have it apart and in pieces in no time.
          Around 3:00AM would be a good time for this to happen.....
          http://www.elksigndesigns.com
          • mschrank
            • Oct 2004
            • 1130
            • Hood River, OR, USA.
            Hey David...I'm doing the same thing this weekend.
            I'll have some help as I invited my parents down to "see the grandkids," but told my mom to pack Dad's crowbar and drill/driver when he's not looking.
            I'm replacing all the decking with 2x6 cedar....jeesh I didn't realize it would cost so much!
            • MikeMcCoy
              • Nov 2004
              • 790
              • Moncks Corner, SC, USA.
              • Delta Contractor Saw
              I have a cousin who used the snatch-em method a couple of years ago and he failed to notice the deck was attached to the house with a ledger board.
              • mikel
                • Jul 2006
                • 202
                • philadelphia
                • bt 3100
                Chainsaw does sould like fun...
                Recip is what I too would use.
                With long agressive blade.
                ...m
                • Hellrazor
                  • 2091
                  • Abyss, PA
                  • Ridgid R4512
                  On a save nothing job...
                  1. Chainsaw if you are really in a take it out on something mood. Beware of nails.
                  2. Reciprocating saw using a wood only blade. Switch blades only if you have to cut nails.
                  3. 3' pry bar
                  4. Hand sledge
                  5. Sledge hammer
                  6. Hammer
                  7. Gloves and safety glasses
                  8. 5gal bucket to throw the nails in
                  9. Cordless impact to loosen the nuts on the ledger and posts
                  • Stan
                    • 966
                    I sincerely hope he had you hold the beer...
                    • jlake1998
                      • 37
                      • Washington
                      I took one out several years ago, It was 8x8. Used a circular saw running perpendicular to the decking cutting it in 1/2 between the the joists. Cut the outer frame on each end. with some help loaded the 2 pieces in the pickup for the dump. Oh on the railing i would cut it off just above deck with sawall or chainsaw.
                      Enjoy building the new one!!
                      • JSCOOK
                        • Sep 2006
                        • 774
                        • Kitchener, Ontario, Canada
                        • Ryobi BT3100-1
                        At our last place when we put on a new deck, I used my Stihl chainsaw with an old chain that wasn't up for much to destroy the old existing one first ... neighbours thought I was a little nuts
                        • TheRic
                          • Jun 2004
                          • 1912
                          • West Central Ohio
                          Did you notice they didn't bother you or argue with you as much afterwards?!
                          Ric
