Stuggling with Sketchup?
  • mschrank
    • Oct 2004
    • 1130
    • Hood River, OR, USA.
    Some recent threads on Sketchup made me realize that a lot of you are starting to use it.
    Gary Katz has pretty good tutorial where he draws a bookcase step by step. He does a decent job of explaining "groups" & "components", and shows how easy it is to use the "push/pull" tool.
    He does a few things differently than I do, but I guess that shows how versatile the program is for different users.
    One new thing I learned is how to use the "follow me" tool...would have been very handy on a recent project. It makes drawing molding & trim very slick.
    Check it out when you have a half hour to kill.
    Thanks for the link, I will check it out when I have some spare time.
    • RodKirby
      • 3136
      • Mao Shan TSC-10RAS
      Absolutely mindblowing! How can they give this software away?
      I finally worked out why I'm having such a problem with Sketchup. I'm color blind (which I knew), and when lines/corners etc change color I'm not aware of it Just have to plug along I guess
      Many thanks for the link.
      Downunder ... 1" = 25.4mm
      • big tim
        • 546
        • Scarborough, Toronto,Canada
        • SawStop PCS
        Thanks for that link.
        I just watch the tutorial. Very informative.
        Tim
          Another "Thank you for the link". I'll check it out later on.
          • radhak
            • 3061
            • Miramar, FL
            • Right Tilt 3HP Unisaw
            Wow!
            This is amazingly good. Best is it is by a woodworker for all of us, so very specific to what I needed to know. (Tho' he calls us 'carpenters' )
            There's stuff here that I would not have ever known, like that 'follow me' tool...
            But boy does it suck up your time...
            - Aristotle
            • dlminehart
              • 1829
              • San Jose, CA, USA.
              His Windows version doesn't match the Mac version very well. His first actions, setting up for a top-down floorplan view, involve clicking on one of a number of house view icons, none of which are visible on the Mac. What gives?
              - David
              • BasementDweller
                • 95
                • PA.
                • nt3100.001
                You should be able to add it:
                Select View Menu,
                Select Toolbars
                click on "views"
                You should now have the houses.
                Click. . . Hey, turn the lights back on! I'm still down here!
                http://www.teraflax.com
                  Thanks for that link, Mike. That helped me understand nearly everything I
                  needed to know to get going with SU.
                  Paul
