Anybody know of a free GUI graphics util that will resize all the photos in a directory with one click? I' have a util but it is command line and I want something easier to use for LOML.
Graphics Utility
The finepix viewer that came with my camera does batch processing, I'm sure a lot of the others do too. Poke around the menu options in a few (picassa maybe?), I'm sure you'll find something.If it ain't broke.. don't fix it!!!... but you can always 'hop it up'
IrfanView does this. Add the files to the Files List, Go to Set Advanced options the check the Resize button, set the size you want.Last edited by Ken Massingale; 04-09-2007, 09:27 AM.Comment
Thanks jaybee. I will check that out. I thought about Picasa but I wanted a lighter footprint. Picasa is a little too intrusive for me.David
You could probably write a simple wrapper for the command line utility, too. Is it ImageMagick?online at http://www.theFrankes.com
"Life is short, Art long, Occasion sudden and dangerous, Experience deceitful, and Judgment difficult." -HippocratesComment
I actually have a command line util called dmesg and I wrote a perl script long ago which will do what I want. However it is not all that user-friendly. Yes, I could write a 'simple wrapper' but a real programmer like my dad could do in an hour or so what would take me several.
Want me to write one for you? What command line utility are you using?online at http://www.theFrankes.com
