Wheelbarrow handles
  • gary
    • 893
    • Versailles, KY, USA.
    Wheelbarrow handles
    I have a metal one wheel one! The handles have rotted and I want to replace them. What wood shall I use if I decide to make them myselves?
    Gary
    Hickory, if you can find it. Hickory is the best overall in my opinion as it is strong and somewhat flexible instead of brittle. Pecan is related to hickory and I found a couple of places selling that as "hickory".
    Other people might have some other and better suggestions.
    • JSCOOK
      • Sep 2006
      • 774
      • Kitchener, Ontario, Canada
      • Ryobi BT3100-1
      I agree with Leehljp and use Hickory if I could, otherwise I'd use oak treated (soaked) with something like boiled linseed oil ... but be carefull with any rags soaked in linseed oil as they can and are know to spontaneously combust
        Rags soaked in BLO (or any of the other flammable finishes) will combust yes, but really only if they are wadded up in the bottom of a can.
        I did some experimenting a while back. The only way I could get it to flame up was to have several soaked rags stuffed in a can with the lid off. With a lid on there was not enough oxygen to support combustion. Basically if you leave the rag fully open to dry you are safe.
          If I had the stock I'd go with white oak.
          • Tom Slick
            • 2913
            • Paso Robles, Calif, USA.
            • sears BT3 clone
            I believe ash could also be used.
            • Daryl
              • 831
              The felow at the flea market with a stack of shovel handles ususlly has a supplyof wheel-barrow handles. I can't remember the price but they are pretty reasonable. Of course you might want to make your own.
