Keep or scrap?
  • bmuir
    • Jul 2006
    • 63
    • Rochester Hills, MI
    Keep or scrap?
    What is the shortest piece of hardwood you keep?
    What is the shortest piece of softwood you keep?
    What is the size of the smallest piece of sheet goods that you keep?
    Thanks,
    So little time, so much wood!
  • linear
    • 612
    • DeSoto, KS, USA.
    I got a set of plug cutters a while back. So I keep almost any hardwood scrap that I can get a 1/4" plug out of.
    Softwood I don't hang on to so dearly, and I use a lot of cull bin sheet goods, so I trash a lot getting rid of mangled edges and so on. I hung on to every square inch of the cherry ply I bought though.
    --Rob
    sigpic
    • RodKirby
      • 3136
      • Mao Shan TSC-10RAS
      H/W = 24"
      S/W = 36"
      MDF = 6" x 6" (about) - good for test cuts on the router.
      Marine ply = 1" x 1"
      Downunder ... 1" = 25.4mm
      • maxparot
        • 1421
        • Mesa, Arizona, USA.
        • BT3100 w/ wide table kit
        Nothing goes to waste. I keep small scraps for fireplace kindling and sawdust makes it to the mulch pile.
        Opinions are like gas;
        • Alex Franke
          • Feb 2007
          • 2641
          • Chapel Hill, NC
          Hardwood - Just like linear, anything I can get a plug out of
          Softwood and sheet goods - probably about 6" for testing cuts, unless it's expensive or suitable for small projects (like drawer bottoms for a small spice rack)
          Unusable stuff is kindling or goes to the compost bin, unless it's MDF or treated.
          maxparot, carful not to use black walnut as mulch for veggies. It'll kill tomatos, peppers, potatos, etc.
          • jackellis
            • 2638
            • Tahoe City, CA, USA.
            I don't throw away anything except MDF and OSB. I'll use the smallest scraps for test cuts, then use what's left for kindling. More than once I've found a way to use pretty small scraps for a part in a shop fixture.
