Say Good-bye!
    Say Good-bye!
    All you folks on this forum can say good-bye to Pappy's Playpen.
Name:	Shaded work area.JPG
  • Sam Conder
    Woodworker Once More
    • 2502
    • Midway, KY
    • Delta 36-725T2
    Expecting a tornado in San Marcos!? If so, RUN NOW to Mamacita's and grab me some Mamatomic Salsa!!!
    Sam Conder
    BT3Central's First Member
    • Hellrazor
      • 2091
      • Abyss, PA
      • Ridgid R4512
      Rumor has it Bob Villa is buying it for his new show...
      • ChrisD
        • 881
        • CHICAGO, IL, USA.
        Sure, Pap, but I hope it's only because it is about to be replaced by a bigger and better one!
        Chris
          Say Hello...
          ...to the new, improved, and BIGGER Pappy's Playpen!
          It is 26'3 x 24'9 inside, about 650 sq ft. Side wall height is about 9'6.
          I found this on Craigslist and made a bid of $1800. Found out I was high bidder about an hour ago. I have about 3 weeks to disassemble and move it.
          Once it is up and ready to occupy, the old Playpen will be moved near by and become a dedicated finish room.
          And, yes, the walkway and sitting area will find their way to the new shop area!
          • Sam Conder
            • 2502
            • Midway, KY
            • Delta 36-725T2
            Looks like it has a decent sized dust collector port there on the front.
            Sam Conder
            • gad5264
              • 1407
              • Columbus, Ohio, USA
              • BT3000/BT3100NIB
              New "Play Pen"
              AWESOME, I for one can't wait to see the new and improved version.
              Grant
              "GO Buckeyes"
              • parnelli
                • 585
                What did they do with it??? That pipe is HUGE!!!!! Is that a water pipe or some kind of beer delivery system?
                Mmmmmmmm beer.
                  Pappy, good score and keep us posted on the progress for your new shop. I know you will put the space to good use.
                  • onedash
                    • Mar 2005
                    • 1013
                    • Craftsman 22124
                    All you need now is some cami net to hide it....
                      Mmmmmmmm beer.
                      There are about 5 pipes coming thru the walls, but not as big as this one. It was a pump house for some kind of chemical transfer. There is some minor damage near the floor in the back from a sulfuric acid spill. That area and the panels where the pipes are will be used where I install windows. Plus from its use is there are 2 exhaust fans. One on the left wall in the picture and the roof vent has a fan in it.
                      • MilDoc
                        Green with envy!
                        • gerti
                          • 2233
                          • Minnetonka, MN, USA.
                          • BT3100 "Frankensaw"
                          I am very happy for you Don! You are going to love the space.
                            Good for you Pappy. Looks like you are going to have plenty of space.
                            • TheRic
                              • Jun 2004
                              • 1912
                              • West Central Ohio
                              Congratulations!!!!! You know what this means, you won't be able to complain about how small of a shop you have.
                              Well, your still complain, just won't be as valid.
                              Ric
