There is a misconception about getting "more rubber on the road" with a wider lower profile tire. The actual footprint of a tire (pattern on the pavement), is determined by the tire width, height, (rim in some circumstances), and the weight of the vehicle. In most cases, the actual footprint is much smaller than a sheet of typing paper (8 1/2" x 11"). A motorcycle tire produces a footprint somewhere around the size of a postcard. Scary thought.
Changing the size of a tire from a factory spec to a lower/wider tire doesn't make a larger print, it only changes in shape. For a taller narrow tire, the patch is longer and and for the wider tire it is shorter but wider. The actual area of the patch in square inches doesn't change, only the shape. This is produced with the weight of the vehicle.
For the difference in driving applications, the most noticeable would be in the stopping forces (braking) applied to the two design examples. The longer patch will afford more friction than the shorter patch. As for cornering, the wider shorter patch will outperform the longer narrow one.
There are also other differences including sidewall height, width, tread design, tire compound and air pressure which affect driving responses.
A THING OF BEAUTY IS A JOY FOREVER - John Keats
