In case there are, I'll post my problem.....
The college that I work at has a third party software package that among other things allows users to access information about their classes, transcripts, bills, etc. on the web. Obviously, the back-end is SQL Server. In the instruction manual, they explain how to bulk-insert users to create their accounts using DTS. I have tested this package on our development server and it works like a charm.
Basically, it takes a csv file and bulk loads the information into a "bulk insert" table. This table has an insert trigger that encrypts the password provided, among other things, and insert the information into another "accounts" table. This "accounts" table is where the application pulls from when the user logs in.
This works well on the test site, but in live, the trigger doesn't fire off. The DTS package executes properly and the data from the csv file is loaded into the "bulk insert" table, but the data is not being transfered from the "bulk insert" table to the "accounts" table via the trigger.
Any thoughts as to why a trigger wouldn't work. Our live server is a clustered server if that makes any difference. I've tried dropping the trigger on the live server and re-creating it with the one from the test server. I even tried running a trace (which I'm not very good at) with no luck.
ideas appreciated.
Thanks,
Pete
ideas appreciated.
Thanks,
Pete
