[Alert: juvenile stream-of-consciousness rant to follow]
I am making an Adirondack chair based on a design from WW Journal. The design is sketched out at 1:5, so I figure this should be no problem, right?
First problem--can't enlarge the picture on copier more than 400%, also a PITA to copy and tape together. Gave up after wasting a couple dozen sheets.
So, I went to get some 1x1" graph paper. Surprisingly hard to find. Looked all over town, finally found some at Office Depot. Then I started transferring the design from little squares to big ones. Had to count out all those little squares, draw freehand curves, etc. More complicated than it looks. Took several hours.
Then, I had to cut it out. Now, I'm pretty good with sharp objects, but it's hard to cut curvy stuff with scissors, especially since I used poster paper for some of the pieces. I think I gave my thumb a blister.
So far, I have spent about 8-9 hours over 3 nights and have done no more than make paper templates for my project. I have yet to cut the first piece of wood.
And then I thought, didn't I do stuff like this in kindergarten? Am I reverting? Will I be demanding a pint of milk instead of Heineken? Should I plan on taking a nap between 1:30 and 2:15 every day on my little mat? Where are the little wooden blocks--oh yeah, I gotta make those, right after I finish transferring and cutting out the paper templates...
