My rider has an annoyance safety feature where when you shift into reverse with the blade engaged it shuts the mower off. Apparently I am too stupid to backup and mow at the same time. Anyhoo, if you have a Troy-bilt Pony tractor, you can take off the cover around the gear shift.
There is a yellow wire attached to the underside of the cover. Disconnect the cable and you can mow in reverse.
