Log in problems
  • meika123
    • 887
    • Advance, NC, USA.
    Log in problems
    Been having problems staying logged in. Matter-of-fact, been having trouble logging in, period. Anybody else having this problem??
    Dave in NC
  • Warren
    • 441
    • Anchorage, Ak
    I thought I was having a problem as I wasn't being recognized when I opened the site. I'd log in, check the "remember me" block and continue. The next time I returned to the site the first page didn't recognize me. Same routine again. I've since discovered that the site is recognizing and remembering me, it just doesn't reflect that on the first page. If I post or go to the forums it shows that I am logged and remembered.
    • messmaker
      • 1495
      • RICHMOND, KY, USA.
      • Ridgid 2424
      I am running into the same problem. The "remember me" function did not seem to be working for the last couple of days. I had some work done on my computer and thought it might be my problem.
        Shortly after the switch to the new software, I was experiencing a problem with the system not showing me all the new posts since my last log-out.
        I then noticed that the home page has TWO log-in boxes: one at dead center, the one which includes provisions for registering; the other at the far right end of the "BT3Central Main Page" bar. Lately I've been using the latter exclusively and have had no problems.
        It's a shot in the dark and may make no difference whatsoever, but you might try that, if you've not already.
        • Warren
          • 441
          • Anchorage, Ak
          The problem is back for me (or maybe it really didn't go away). I can't stay logged in. I've tried both ways of logging. It's intermittent but, only a little aggravating.
          • Sid
            • Apr 2004
            • 139
            • Bloomington, IL, USA.
            • Craftsman 22124
            I've had a problem staying logged in too. It seems to help if I enter the forums and then log in instead of logging in at the main page.
            Sid
            • Warren
              • 441
              • Anchorage, Ak
              Everythings been hunky dorie (never used that exclamation before, did I spell it right?) for the last two days for me. Just following the normal routine and everythings seems back to normal.
