I learned that the Craftsman micro torque wrench is $26 off. I also learned to consider something else since they don't have a lifetime warranty but the Husky and HF ones do.
What did you learn today?
Ok, that is funny. I figured I should consider something else because of it's limited size range...you know...9/16 to 9/18. I've had to torque a lot of 9/16 nuts in my life, but haven't seen many 9/18!
I find television very educating. Every time somebody turns on the set, I go into the other room and read a book. - Groucho Marx (1890-1977).
And POOF! all of the data in your table is gone. If you're using mysql 5, use the new transactions ("BEGIN WORK"; do stuff; check it; COMMIT; ) feature when you're doing big stuff like that, assuming you're using a back-end that supports transactions. At least you'll be able to roll back mistakes.
Jeff
Jeff
I learned that even with only 2 posts that you can still end up being famous and making the history books around here.
Congratulations to jxyoung for his time in the spotlight here at BT3Central!!!!
I'm sure at one point that his post count had to be higher than anyone else around here. I think he also did it in the least amount of time, but Mike (silverfox) MIGHT still have him beat.
If it ain't broke.. don't fix it!!!... but you can always 'hop it up' **one and only purchaser of a BT3C official thong**
