Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 98
Thread: Grizzly BS blade tensioner on a HF BS
  1. #61
    Join Date
    Apr 2008
    Location
    League City, Texas
    Posts
    7,413
    Quote Originally Posted by jonmulzer View Post
    (1) P0555137 BRACKET
    (2) P0555140 SUPPORT PLATE
    (1) P0555133 LEVER ROD
    (1) P0555135 BUSHING
    (1) P0555141 FIXED BASE
    (1) P0555033A BLADE ADJ SCR ASSY 7" THREAD
    I think that is the same as your order. I have not compared the minutiae of the numbers, but at a glance I think they are the same?
    That looks about right.
    What components are we missing? According to the phone rep from Grizzly, 130 A&B and 131 A&B are included in P055033A Blade Adj Screw Assembly 7".
    My personal workshop blog is http://daves-workshop.blogspot.com. My camping / hunting / outdoor blog is http://wildersport-outdoors.blogspot.com/
  2. #62
    Join Date
    Dec 2007
    Location
    Indianapolis, IN
    Posts
    946
    The ones he said were included, were not on mine. Maybe my screw assembly was missing parts? I had to order them separately. I have also somehow misplaced them since I received my second order.
  3. #63
    Join Date
    Apr 2008
    Location
    League City, Texas
    Posts
    7,413
    You were dead on right, stan was WRONG, well maybe not when he posted, and in all fairness, the grizzly rep I talked to goofed too... What a PITA...
    Oh well, now to Ace Hardware to grab the misc fasteners...
  4. #64
    Join Date
    Dec 2007
    Location
    Indianapolis, IN
    Posts
    946
    I was REALLY hoping I was wrong so they would send me the parts to replace the ones I ordered the second time and that disappeared into the wormhole. I have looked everywhere. Looks like I am going to have to re-re-order them!
  5. #65
    Join Date
    Jul 2008
    Location
    Mather, CA
    Posts
    114
    Can you two make up your mind and post the correct order numbers please!?!?!? Much appreciated.
  6. #66
    Join Date
    Apr 2008
    Location
    League City, Texas
    Posts
    7,413
    Quote Originally Posted by pbui3057 View Post
    I have double and triple checked the part #s against the Grizzly G0555 parts list. The previously mentioned part number change that Stan listed on the second page of this thread is currently wrong information. But that is a very old post too... Current correct information is as follows...
    33 P0555033A 1 Blade Adj. Screw Assy 7"
    130A PSS05M 1 Setscrew M5-.8x10 (Get this from local hardware store if possible. I could not find these locally.)
    130B PSS07M 1 Setscrew M5-.8x5 (Get this from local hardware store if possible. I could not find these locally.)
    131A P0555131A 1 Fixed Spacer A.
    131B P0555131B 1 Fixed Spacer B.
    133 P0555133 1 Lever Rod
    135 P0555135 1 Bushing
    137 P0555137 1 Bracket
    140 P0555140 2 Support Plate
    141 P0555141 1 Fixed Base
    Now the rest of this stuff SHOULD be findable at your local hardware store for a LOT less money than Grizzly sells it.
    If you are wanting to go with the Metric to be 100% up to speed with Grizzly, the parts are...
    132 PW04M 1 Flat Washer 10mm
    134, PW01M 6 Flat Washer 8MM
    136, PSB82M 1 Button Cap Screw M8-1.25x20
    138, PB15M 2 Hex Bolt M8-1.25x40
    139, P0555139 2 Nylon Nut M8-1.25
    142, PLW04M 2 Lock Washer 8MM
    143, PB09M 1 Hex Bolt M8-1.25x20
    Following the original instructions, I am going with 5/16" SAE mostly because I have the SAE tap & die set from way back when... Those components are...
    2 @ 5/16-18 bolts 1 1/2"
    2 @ 5/15-18 bolts 3/4"
    1 @ 5/16-18 button cap screw 3/4"
    7 @ 5/16 flat washers
    2 @ 5/16 lock washers
    2 @ 5/16-18 nylon locking nuts
    FWIW, I use a LOT of 5/16" hardware, and intend on picking mine up in full box quantities at Ace Hardware. My local Ace gives full box discounts...
  7. New info on this mod?
    The original link is dead. I would love to add the grizzly blade tensioner to my saw.
  8. #68
    Join Date
    Apr 2008
    Location
    League City, Texas
    Posts
    7,413
    I would HIGHLY recommend you read the text of this thread, then read the article I wrote on the subject HERE, and follow that up with reading my blog series (7 parts) on Hot Rodding a Harbor Freight bansaw that I put up on Lumberjocks a while back... It can be found HERE.
    IF after all that, you still have questions, send me a private message with your email address and I will answer anything I can for you...
    This is a very worth while modification, and it is very easy to do, but I do not recommend it for the mechanically squeamish as it DOES involve drilling into the frame of the saw... Any mistakes / breaking or messing up expensive parts is your responsibility...
  9. Thank you -exactly what I was looking for!
    The links you provided are what I need to finish the mod. So far I have converted over to one speed and a new single belt - huge improvement! The saw came with a new 1HP motor and now I will be beefing up the wimpy motor mount. New graphite guide blocks are on the way along with a new fence and tires and blade from Carter. I will be ordering the Grizzly parts in the AM and will post pics as I do the mods. If I do the riser block I will be swapping the motor from my table saw over to the band-saw and adding a 2 or 3 Hp motor to the table-saw and moving the band-saw motor over to my underpowered drill press.
    Steve
  10. #70
    Join Date
    Apr 2008
    Location
    League City, Texas
    Posts
    7,413
    I had originally planned on the motor upgrade, but haven't really needed to. I just run the saw on the fastest speed and it just hums along nicely... Then again, I am patient...
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
