Very new to this forum, about 5 minutes. Been lurking for a few weeks though. Just picked up a BT3000. I need to get back to working this week and needed a larger capacity table saw. I liked the extension rails available for this saw, and it should work perfectly. I obviously got the saw used, but it is in great condition. It only looks as if the saw was used 5 times or so. Or it was very well taken care off. However, i am in the process of adjusting everything: SMT, rip fence, scale, etc....I want everything perfectly the way I want it. Although, I seem to having a big problem with the sliding mitre table.
I will explain as good as I can. The SMT has major play right to left in the front (There is one eccentric screw and a standard silver one), it moves about a 1/4"...maybe a little less. The back seems ok and workable. However, there is not enough movement in the eccentric screw to close the gap and prevent it from moving left and right. I cannot continue to square the table to the blade until I can stop this play.
I will never get an accurate miter cut like this. Has anyone else had this problem? The tabs on the bottom of the screws are in perfect condition.....
