Plunge router bits
  • sailor55330
    • Jan 2010
    • 494
    Plunge router bits
    Hi again. I just acquired my first plunge router and have not even unbowed it yet. From what I am reading it apprears that there are special plunge router bits that should be used. Obviously I don't have any
    can anyone please confirm that there is such a thing a a plunge router bit and does anyone have a recommendation for a good basic set?
    thank you
    • 10453
    They don't show a set but MLCS has plunge straight bits.
    Additionally, many of the round nose, sign cutting and core box bits can be used to make plunge cuts.
      Internet Fact Checker
      • 20989
      Yeah, plunge router bits have to have cutters that meet in the center. If they don't, the center under the bit won't get cut as you plunge it and it'll just burn under the bit!
      See the bit pictured on this page of MLCS's catalog
      https://www.mlcswoodworking.com/shop.../bt_plung.html
        Just me
        • 8442
        Here is a list of bits from MLCS that can be used in a plunge situation:
        GROOVE FORMING
        Bottom Cleaning
        Bowl & Tray Dish Cutter
        Core Box
        Dish Cutters
        Flat Bottom Round Over
        Hinge Mortising
        Point Cutting Round Over
        Round Nose
        Screw Slot
        Sign Lettering
        Solid Carbide 45°/15° Sign Making NEW!
        Solid Carbide 60°/90° Double End NEW!
        V-Groove
          • 10453
          Add Key Hole bits to the list.
            You may realize this but, just to be sure, plunge routers can be used for cuts other than plunging into work, like to make a mortise, and when they are doing an edge route, they use the same bit as a fixed base router. I use the motor off an old plunge router in my router table. It is only for plunging into work that a different bit is recommended. Not required but recommended. I have plunge cut with regular straight bits but it is rough going on you, the router, and especially the bit. Either a straight bit with a bottom cutter or a spiral bit will plunge a lot better. But plunge routers can be general purpose routers using many other bits.
            • tfischer
              • 2343
              In a pinch you can also drill a starting hole, and "plunge" into it with a standard bit.
