guide holder stuck
  • chrisv256
    Handtools only
    • May 2012
    • 2
    guide holder stuck
    Hello everyone. I just bought a bt3000. I've been taking it apart to check and repair anything I find along the way. The shims need to be replaced as well as the belts but I can't get the guide holder off.
    I tried a soft mallet on the shaft. I tried a light bulb to heat it up. I tried pb blaster thinking it was seized. I can grab the two bolt rive knife holder and move it up and down about 1/2 an inch. This is of course after I removed the four screws. The two other screws were not there and the circular thing behind it with screw holes rotates freely.
    This is bad. Any ideas?
  • chrisv256
    Handtools only
    • May 2012
    • 2
    I freed it. Leverage on the opposite side finally dislodged it.
      • 9236
      Sorry I didn't notice your question previously. Glad to know you got it working...
        • 4715
        Good to hear. I got busy at work while contemplating what advice to give. Welcome to BT3Central.
