10" 60 tooth finish blade only $10
    • 3195
    Was in the Borg Saturday and they have their big holiday tool sale displays out and I noticed a 2 pack of their Avanti Pro 60 tooth blades on sale for $19.97. No they are not a Freud blade and you do get what you pay for but at essentially $10 each that is way less than a resharpening. I have some projects that require clean cross cuts so even if they end up dull after that it was worth it. I had one of these before that I bought specifically for a project where I had to cut 4 rooms worth of laminate flooring and they did a good job and saved my good blades.
    http://www.homedepot.com/p/Avanti-Pr...60PP/203560978.
    I have also resold used blades like this at yard sales when they are no longer sharp enough for my quality but still good enough for many.
    I hope to give one a try in the next couple of days and will let you know if there are any issues.
    • 1865
    Thanks Jon - seems like a decent price, might need to pick a set. Appreciate the posting!
    • newbie2wood
      • Apr 2004
      • 453
      • NJ, USA.
      $24.97 in NJ. Is there a coupon code?
        • 3195
        In my store there was a sign that said $24.97 but another that showed reduced to $19.97. It rung up aty the higher price but they reduced it when I told them about the other sign.
          • 3570
          I checked out HD's offerings yesterday. They have a lot of pretty stuff on display! These blades are displayed as $24.95. I went ahead and picked up 1 pkg, knowing that they will be $19.95 Thanksgiving day. I feel like the additional $5 is well spent not having to get involved in the turmoil, and I don't want to make their employees work on Thanksgiving day.
            • 3195
            Got distracted as usual. Only tried these out yesterday. They performed pretty well on some old plywood. Did get a little tear out on the edge but I think it's the plywood not the blade. As its setup I will run some better ply through later and compare.
            Sent from my SM-N900V using Tapatalk
            • sailor55330
              • Jan 2010
              • 494
              I have used these blades on multiple occasions. They seem to cut fine when they are new, but they do seem to lose the edge fairly quickly. I find them to be more than adequate for shop projects (jigs, shelves, etc). I did use the 60t on a jewelry armoir that used maple plywood. It did fine in the beginning but by the end of the project, I noticed a little increase in tearout.
              for $10 a blade, hard to go wrong.
              • newbie2wood
                • Apr 2004
                • 453
                • NJ, USA.
                Looks like the same deals this year at Home Depot for the Advanti blades.
                $19.97 10" Advanti Pro (2-Pack)
                $34.97 12" Advanti Pro (2-Pack)
                $5.97 7-1/4" Advanti Pro (2-Pack)
                • Woodshark
                  • May 2006
                  • 158
                  • Atlanta
                  I bought a pack just to have. Really hard to go wrong at $10 a blade. I'm using one from last years sale and it is still holding a fairly good edge.
                  sigpic
                  • os1kne
                    • 901
                    • Atlanta, GA
                    I picked up a 2-pack, and for $10/blade they're pretty good. If you happen to be doing a laminate flooring install or something similar these would be great. (I quickly made a decent blade unusable for woodworking after the last time I installed laminate flooring. Now, I'll be spending way more than $10 to get that blade sharpened.)
