Useful Info on Penetrating Oils
  • annunaki
    • Jan 2008
    • 610
    • White Springs, Florida
    • 21829, BT3100, 2-BT3000(15amp)
    Penetrating Oils
    Machinist's Workshop Mag recently published some information on various
    penetrating oils that I found very interesting. Some of you might appreciate
    this. The magazine reports they tested penetrates for break out torque on
    rusted nuts.
    They are below, as forwarded by an ex-student and professional machinist. They
    arranged a subjective test of all the popular penetrates with the control being
    the torque required to remove the nut from a "scientifically rusted"
    environment.
    Penetrating oil Average load
    None
    516 pounds
    WD-40
    238 pounds
    PB Blaster 214
    pounds
    Liquid Wrench 127 pounds
    Kano Kroil
    106 pounds
    ATF-Acetone mix 53 pounds
    The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic
    transmission fluid and acetone. Note the "home brew" was better than
    any commercial product in this one particular test.
    Our local machinist group mixed up a batch and we all now use it with equally
    good results.
    Note also that "Liquid Wrench" is almost as good as "Kroil"
    for about 20% of the price.
    Steve from Godwin-Singer says that ATF-Acetone mix is the best and you can also
    use ATF- lacquer thinner 50 - 50 mix.
    ATF=Automatic Transmission Fluid
    http://en.wikipedia.org/wiki/Fileodecahedron.gif
  • sweensdv
    • 2873
    • WI
    • Baileigh TS-1040P-50
    Did they also measure the amount of time it took the penetrating oil to penetrate?
      That's a good comparo. Who woulda thunk ATF & acetone.
      • annunaki
        • Jan 2008
        • 610
        Update RE: Power Steering Fluid (last paragraph)
        It looks like the original article was in the April/May 2007 issue of Machinists Workshop.
        Quote:
        Machinist's Workshop magazine actually tested penetrants for break out torque on rusted nuts. Significant results! They are below, as forwarded by an ex-student and professional machinist, Bud Baker.
        Don't forget the April 2007 "Machinist's Workshop" magazine comparison
        test.
        *They arranged a subjective test of all the popular penetrants with
        the control being the torque required to remove the nut from a
        "scientifically rusted" environment.
        *Penetrating oil ..... Average load*
        None ..................... 516 pounds
        WD-40 .................. 238 pounds
        PB Blaster ............. 214 pounds
        Liquid Wrench ..... 127 pounds
        Kano Kroil ............ 106 pounds
        ATF-Acetone mix....53 pounds
        *The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission
        fluid and acetone.*
        *Note the "home brew" was better than any commercial product in this one
        particular test. Our local machinist group mixed up a batch and we all now
        use it with equally good results. Note also that "Liquid Wrench" is about
        as good as "Kroil" for about 20% of the price.
        The results have been widely quoted on the internet, but the picture in the magazine allegedly shows power steering fluid and not ATF, and according to lbender (who claims to be the author) in this thread, it actually was power steering fluid (mixed with acetone) that they tested with.
          • 22060
          The same report was quoted and there was a lengthy discussion thread on this topic last October
          http://www.bt3central.com/showthread...power+steering
          • annunaki
            • Jan 2008
            • 610
            Thanks- Must've missed it.
              Others might have also missed it. Thanks for posting it.
              • toolguy1000
                • Mar 2009
                • 1142
                • westchester cnty, ny
                and another thank you. liquid wrench has been my preferred penetrating oil since i was a pup helping dad work on the family cars back in the 60s. couldn't have successfully refurbished the unisaw i sold without it.
                • cork58
                  • 365
                  • Wasilla, AK, USA.
                  I've been using ATF and acetone for many years and up till I got got wd for fishing, he let me off though if I made him that promise no to use it anymore. Some of my lures may get a little on them while I'm spraying my reels (or my hands).
                  Cork,
                  • annunaki
                    • Jan 2008
                    • 610
                    What a Fish story!
                    From WD-40's own site:
                    http://wd40.com/about-us/myths-legends-fun-facts/
                    What a Fish story!
                    Myth: WD-40 contains fish oil.
                    Fact:
                    Consumers have told us over the years that they have caught some of the biggest fish ever after protecting their fish hooks and lures with WD-40. We believe this legend came from folks assuming that the product must contain fish oil since it appears to attract fish. Sorry Charlie®, it just ain’t so.
                    WD-40 Company has taken steps to respect and conserve the environment, and encourages its users to do the same. While WD-40 can be used to help protect fishing equipment from rust and corrosion, WD-40 Company does not recommend using WD-40 to attract fish.
                    • annunaki
                      • Jan 2008
                      • 610
                      "Others might have also missed it. Thanks for posting it."
                      Thanks Cabinetman !
                      • annunaki
                        • Jan 2008
                        • 610
                        However for diehard WD -40 Lovers here are_
                        2000 + Uses
                        http://wd40.com/files/pdf/wd-40_2042538679.pdf
                        40 More uses
                        http://wd40.com/files/pdf/wd-40_2023968175.pdf
                        Bike Full of uses
                        http://wd40.com/files/pdf/wd40-ful95617348.pdf
                          I also remember Liquid Wrench as a kid, along with other standby's (not penetrating oils), like Neatsfoot Oil, 3 in One Oil, and Brasso.
                          • gsmittle
                            • 2793
                            • St. Louis, MO, USA.
                            In a box of my dad's stuff after he died, I found a can of 3-in-1 oil he used to clean his guns. I still use the same can for the same thing.
                            g.
                            Smit
                            "Be excellent to each other."
                            Bill & Ted
