Mobile Cabinet (Still)
  • ghofer
    • 15
    • Santee, CA, USA.
    I've been away, but see that mobile cabinets are still a problem for some. About a year ago I built a mobile cabinet on a 3 point support (with 4 casters) that drew some attention, but I see that post has fallen off the site. I've been using my saw most days since then, moving it out then back under my workbench with absolutely no alignment problems. Since I built the frame a year ago, I've put shelves in it and doors on it. Here are the photos of the frame. If you'd like more info, I'll be happy to provide it.
    Gordon
  • rbfunk
    • 400
    • Garfield, NJ, USA.
    Gordon,
    I just started my mobile stand and was wondering if those are two way locking casters. If not, how do you keep the saw from moving? I've got some one way locking casters and no money for new ones. I've also got a few ideas for locking it but always looking for a better idea.
    Thanks,
    Bob
    Oh what a tangled web we weave, when we are all hopped up on caffine.
    • ghofer
      • 15
      • Santee, CA, USA.
      Bob,
      The casters aren't locking, but could be. The whole thing is fairly heavy (I wouldn't try to pick it up), and just doesn't move. About the heaviest stock I've cut is 4 x 4 pressure treated redwood, and it won't go very fast, so I guess I just don't push on the saw very hard.
      Gordon
      • Mainemarc
        • 673
        • Portland, ME, USA.
        Hi Gordon:
        We had a server meltdown a few months back and a lot of data was lost. So don't take personally the fact that your post has "fallen off the site".
        I'd be very interested in more details on your mobile base. You mention the fact that it's a 3 point support (with 4 casters). I can see in the second picture that you've got something going on between the two outfeed legs, but I can't see exactly what. I'm guessing that and the two casters on the opposite end are the 3 points of support.
        Can you get us a picture from the other angle and a description of that third support? I'm guessing whatever it is also locks your mobile base in a stationary position.
        Also, how high is your table saw surface with the mobile stand?
        Marc
        • ghofer
          • 15
          • Santee, CA, USA.
          Marc, I didn't think I'd been treated unfairly, I just thought my post "aged out."
          The two left end casters are fixed to the frame. The two casters on the right end are mounted to a separate "pivot arm." The pivot arm is secured to the frame by a 3/4 x 6 bolt. The two left end casters and the pivot bolt form a triangular plane (any 3 points in space form a plane). As the frame moves across my uneven floor, the casters on the right end pivot up and down, but the triangular plane supporting the frame remains "rigid." That triangle tilts slightly, with respect to the center of the earth, but not with respect to the frame. Ergo, no racking.
          The second picture shows how I first tested it, by blocking up one caster and rechecking alignments on the saw.
          Gordon
          • ghofer
            • 15
            • Santee, CA, USA.
            Marc,
            Sorry I missed your 2nd question. It's 37-3/4 from the floor to the saw surface, so that by removing the fence and the SMT, it rolls nicely under my workbench.
            Gordon
            • Mainemarc
              • 673
              A mobile stand with an active suspension. Ingenius!
              Gordon, you've got one tall workbench!
              Marc
              • Jim-Iowa
                • Mar 2005
                • 769
                • Colfax, Iowa, USA.
                Nice job! I would not have thought to build a walking beam suspension!
                It`s a great solution to irregular surfaces.
                I sometimes envy you guys with the 3000, the base is more adaptable than the splayed legs on my 3100 stand.
                I think when I build a base I`ll shoot for an overall height of the table at 34-35". I find it a bit high at standard height.
                I would rather have it the same height as my workbench so it can do double duty as an outfeed table.
                Sanity is just a one trick pony. Being a bit Crazy is a wide open field of opportunity!
                • Stick
                  • 872
                  • Grand Rapids, MB, Canada.
                  I was thinking the exact same thing! I like the old style stand much better!I love the idea, but even that wouldn't work well on my floor (old dairy barn, very rough uneven concrete dating back to the mid 1930's) so alas, mine sits stationary with its wide table and full mdf sheet sized outfeed/assembly table. Takes up 1/4 of the shop. But then again, it IS nice not to have to move it all the time.
                  • ghofer
                    • 15
                    • Santee, CA, USA.
                    [/quote]
                    Marc, because LOML parks her car in my "shop" every night, I had to make the workbench tall enough to get my saw out of the way.
                    Gordon
                    • mschrank
                      • Oct 2004
                      • 1130
                      • Hood River, OR, USA.
                      This looks like a great alternative to the torsion box base design that some others have used...much more simple.
                      Couple of questions: What did you use for the top...it looks like 3/4" mdf. How did you attach the end of the rails to the frame?
                      Thanks,
                      • ghofer
                        • 15
                        • Santee, CA, USA.
                        Thanks,
                        Mike, The top is 3/4 MDF. The ends of the rails are attached to the top, using the brackets that came with the rails in the wide table kit, and the top is mounted to the end of the frame. I got the added table as level as I could and cut the vertical supports to match, then used the adjustability of the rail brackets to get it precise.
                        Gordon
                        • Tube Crafter
                          • 60
                          • Austin, TX.
                          It's really a shame Ryobi discontinued the original square stands. The triangulated stand supplied with newer saws wastes a lot of valuable garage, errr shop, space. My other beef is that the blade wrenches won't slip onto the Ryobi tool holders provided with the stand. Does anyone know of an inexpensive, commercially available alternative to the original square stand? I don't mind drilling a few holes to match the saw frame.
                          • Mainemarc
                            • 673
                            Ghofer:
                            I understand completely. I just wanted to make sure you didn't have a former life as an NBA star.
                            Tubecrafter:
                            I read somewhere (Sam's original review?) that the suspicion is that Ryobi went with the splayed stand on the BT3100 so it would look more like a regular saw; somehow making it more appealing to the mainstream saw buyers. A triumph of form over function!
                            I think the hooks are supposed to be used to hold the miter and rip fences, not the blade wrenchs (although it would have been nice if the hooks were narrow enough, or the wrench holes wide enough, to do double duty.)
                            FWIW, I built a simple MDF shelf for mine, it sits atop the lip of the lower braces. No fasteners, it's sized so it can't shift more than about 1/4" in any direction. I just made it in two pieces so I could slip it up from below. It's home to my push sticks, wrenchs, feather board, safety glasses, etc. A bit of a dust magnet, but it does work.
                            Marc
                            • eglosenger
                              • Jun 2005
                              • 19
                              • Berwick, PA, USA.
                              Gordon,
                              I really like the simplicity of you mobile cabinet.
                              Ed Glosenger
