How can I build a bomber miter sled?
  • CptanPanic
    • 77
    • Lake Worth, FL
    Well with the change over to the new forum, I can not longer view the old pictures. Does anyone have pictures for a bomber miter sled, or any other miter sleds you would recommend?
    Thanks,
    CP
  • Stytooner
    Roll Tide RIP Lee
    • 4301
    • Robertsdale, AL, USA.
    There is a photo of mine in use here.
    http://www.leestyron.com/chesstable1.php
    Scroll down the page some.
    Pappy has a nice one as does Rod, Ryan and several others that I have seen.
      Cut mine apart last week to get the fences off. Hopefully they will be mounted to the new version today.
      • CptanPanic
        • 77
        • Lake Worth, FL
        Pappy,
        Take some detailed pics when you finish your new sled.
        Thanks,
        CP
        • RodKirby
          • 3136
          • Mao Shan TSC-10RAS
          Dark side version
          Worthwhile building - takes all the pain away.
          Downunder ... 1" = 25.4mm
          • L. D. Jeffries
            • 747
            • Russell, NY, USA.
            Nice looking jig. What or how is it riding on the table top? I've built one but like yours better and would like to copy it.
            RuffSawn
            • CptanPanic
              • 77
              • Lake Worth, FL
              Ok so I have a question, when you attach the two pieces to the top, how do you align them? I just finished a quick prototype and the right piece's miter was a saw kerf longer than the left. Which means my intersection wasn't exactly in the middle of the saw kerf. So how did you guys do it?
              Thanks,
              CP
              • RodKirby
                • 3136
                Thanks,
                CP
                I hope this makes sense:
                Step 1
                • Cut the base to size
                • Accurately mount the miter slot runners underneath the base(needs a topic on it's own)
                • Mount the sled and cut the kerf as far into the sled as you want it.
                Step 2
                • Make the miter fences - including gluing sandpaper on them.
                • Using an ordinary miter fence, cut the ends of the fences at 45° (or as close as you can)
                • With the new sled on the table saw draw it back until the point at which you want to mount the fences doesn't reach the saw blade.
                • Using ONE of the new fences, yellow glue it as accurately as you can to the sled. Align it to the saw blade at 135°. Position the mitered end as close to half way into the (empty) saw kerf, as you can. Tip: use weights to "clamp" it in position
                • When the glue dries (say 2 hours), carefully turn the whole thing over and screw thru the base to permanently attach this fence.
                Step 3
                • Position the sled on the saw table (now with only one fence attached), pull the sled back so it's not near the blade and...
                • Position and glue the second fence (at 90° to the first fence) so it's TOUCHING the first - the points should meet. The 90° alignment is CRITICAL, not whether the the ends of the fences are a perfect match.
                • Once again, turn the whole thing over and screw the second fence to the sled.
                • You will now have both fences meeting (and aligned).
                Step 4
                • Mount the sled (back from the blade) and turn it on.
                • Move the sled toward the blade slowly and let it cut the kerf in the fences - the blade can handle the sandpaper if you've used it.
                  In progress pictures are forthcoming. Lost most of today working on the Airstream. Eldest will be home tomorow and I had to get it so he can use it as a bedroom. The power convertor/battery charger is shot but I was able to get the 110 power working right.
                  • Otter
                    • 865
                    • Cumming, GA, USA.
                    • Delta Left Tilt UniSaw
                    FAQ candidate.
                    Great instructions Rod...
                    Simple and clean, like every thing else you do.
                    Thank you.....
                    T.E. Lawrence
                    • jarhead
                      • 695
                      • Boynton Beach, FL.
                      Rod,
                      That's a nice miter sled - ShopNotes featured a similar sled one or two issues ago.
                      • CptanPanic
                        • 77
                        • Lake Worth, FL
                        You are right, I looked it up on the Shopnotes site, and it was issue #85 http://www.shopnotes.com/main/sn85-toc.html . It looks just like Pappy's. Anyone have that issue to scan the article?
                        • jarhead
                          • 695
                          I can scan it for you as long as you can wait a week or two.
                          • CptanPanic
                            • 77
                            • Lake Worth, FL
                            Sounds good.
