Right forum? Blast gates
    I picked up the HF dc and plan on doing the Wynn conversion. I am still waiting on the Accessory kit (out of stock, yet they had the collectors). I am wondering about store bought verses homebrewed blast gates. Anyone care to share their experiences.
    TIA
  • Scottydont
    • 2359
    • Edmonds, WA, USA.
    • Delta Industrial Hybrid
    My opinion about store bought blast gates is the good ones cost too much and the cheap ones are exactly that cheap. I make my own gates and they are easy to make and good lookin' too. You can design the mounts to accomodate each location. The plans were in a woodworking magazine Workbench Dec. 2003.
    Here's an assembly tip:
    Put a folded over sheet of copy paper between a the two halves and the slaiding gate before gluing and screwing. You get a consistent tolerance and minimize stickiness or loose leaking gates.
    Here's a couple of pics. (You can double-click them to see a larger detailed pic.)
    Scott
    Edmonds WA
    No coffee, no worky!
    • dlminehart
      • 1829
      • San Jose, CA, USA.
      They look beautiful, Scott. How does the pipe stay in them? How'd you cut the circles?
      - David
      • Scottydont
        • 2359
        • Edmonds, WA, USA.
        The screws that are the center ones in the side, penetrate the pipe. I also used PVC adhesive on the pipe when they are assembled. The holes question is a common one. I used a circle cutter but it quickly dulled. Now I use a router template.
        Scott
        Edmonds WA
          Thanks. And what did you do to get that flex hose to stay put, glue?
            I can tell you that Scott's gates work great. I shamelessly copied his design for my own system. I placed my gates at the end of the run, attached to the pipe with screws and silicon chaulk. For the machine end, I bougth a 4" hose connector, cut it in half and epoxied it in. I used quick connect couplings on the ends of my hoses and they just slip over the coupling half so I can move/remove the hoses as needed.
              I have the same magazine as Scott and use the same type gates. I had the plastic store bought gates initially but they never open all the way and wouldn't close all the way after use because the slot fills up with sawdust. This design works much better. I have also modified the concept to work on in-line gates - all you have to do is assemble by glueing up layers (with spacers - I use a couple business cards, a bit more clearance than Scott suggests - I tried one but it seemed a bit tight but probably would be fine once broken in a little). I have made them of plywood as thin as door skin, 1/2 inch baltic birch scraps, and 3/4 birch scraps. The thicker plywood is easier to work with but all function fine.
              To attach pipe my favorite method is to split a pipe coupling and make the hole in the plywood big enough for the coupling. This may require a bit bigger plywood piece than the magazine design shows. The coupling is sturdy enough to screw to the plywood and the pipe then slips into that (the screw heads keep it from going too far). My favorite way to attach the hose is to use the piece of the 4 inch drain pipe that is made to fit over the next piece of pipe. My flex hose can be forced into this slightly larger ID. It's tight but that helps it not leak. A couple wraps of aluminum tape (duct tape will do but isn't quite as good) and you have a strong virtually leak tight joint.
              I drill the holes with a HF adjustable hole driller. It burns the plywood if you try to go very fast and I don't like that aspect but it works. It was also cheap. I have to make several test holes to get the size right but you can then make several gates pretty fast. The holes are not straight-sided - one end is tighter than the other - but that isn't all bad.
              • Tom Miller
                • 2507
                • Twin Cities, MN
                I see no one has presented "pros" for store-bought, so I'll present what I know.
                I use the metal ones that you see at Woodcraft/Rockler/etc. The nice thing about these is that they fit snugly on my 4" S&D pipe. Uhhh, and they're a little less bulky. I guess that's about it.
                Rockler has 25% off all DC stuff, so they're going for $7.50 at present (regularly inflated price of ~$11).
                Regards,
                p.s. If you make your own, be sure to make enough extra for down the road so you don't have to go through setup time again.
