Need some hinge help - now with picture
  • Sam Conder
    Woodworker Once More
    • 2502
    • Midway, KY
    • Delta 36-725T2
    It wasn't the fumes. The statistics section was always there, but I did add the "Who's online" part. I'm glad you like it.
    Sam Conder
    http://www.samconder.com
    Sam Conder
    BT3Central's First Member
  • Flores
    • 166
    • Fort Worth, Texas, USA.
    Where can you find the "Board Statistics" and the "Who's online" part?
    Flores
    Flores
    • Sam Conder
      • 2502
      • Midway, KY
      • Delta 36-725T2
      At the bottom of the main forum page: http://www.samconder.com/bt3k/forum
      Or in more detail by clicking on "Active Users" on said main forum page. That link takes you to http://www.samconder.com/bt3k/forum/active_users.asp
      Sam Conder
      Sam Conder
        • 8807
        Sam Conder
        I like that Sam, - and don't mind cookies because I have control of them.
        I am a little worried about the way MS is going in KNOWING who is online and what they are doing TO and IN my computer without my knowledge though. I am just not ready for that. The following site shows sixteen ways that they check the ongoing of a persons computer and who knows what else.
        http://www.hevanet.com/peace/microsoft.htm
        Hank
        • TheWoodWizard
          • 296
          • WilkesBarre, Pennsylvania, USA.
          Nice addition Sam.
          Lee: I have been using zone alarm for quite some time now,also have ad-aware in it,and a big plus was putting in guard dog software,it lets me know when any thing I have in this puter is trying to be accessed and gives me the option to accept or reject,it does a lot more also.
          Things worth doing,are worth doing right the very first time!!
          If things get better with age,then I must be approaching magnificent!!
            Here is a picture of the foosball table. The orignal hinges went on the top edges and are as wide as the sides are thick - so not very. What I want to accomplish is something a little stronger than the origanl while allowing the table to fold closed.
            • inkhead
              • 15
              • Olathe, Kansas, USA.
              crokett,
              I just received some hinges from Austin Hardware today.
              Take a look at these.
              http://www.austinhardware.com/
              Hope it helps
              Jeff
              \"I am not young enough to know everything.\"
                Jeff,
                Thanks but that is not what I need either. I will look at it again tomorrow. There may be a way to use different hinges and still have it work.
                  I get it...I think. I've never seen a hinge like what you're looking for. Sorry
                    If by fold closed you mean you want the top of the unit to close up on itself (fold top to top), you need the center line of the hinge to be on the top corner of the pieces. You could do this if you are willing to glue some more wood on to have something to fasten a decent sized hinge to. It looks like it would be in the way of the handles, however.
                    What about putting a door hinge or a clasp flat against the side? When you want to use the table, you put the hinge pin into the two pieces of the hinge and it will be rigid. When you want to put it away, you pull the pins from each side and you can put the pieces on top of each other for storage. You could use clasps like you sometimes see on industrial boxes, they surface mount and there is a wire ring that goes over the other piece of the hinge and a lever to pull things down tight.
                    • Deadhead
                      • 490
                      • Maidens, Virginia, USA.
                      Something along the lines of this?
                      http://www.vandykes.com/product/02218758/
                      "Success is gettin' what you want; Happiness is wantin' what you get." - Brother Dave Gardner (1926-1983)
                        Kevin,
                        That is exactly what need. I will keep that link. I will look around a bit, don't need anything that fancy, but the style will work. Thanks for the information.
