I was bullied into this report here http://www.bt3central.com/forum/topi...90&whichpage=1
By bruffc
So unfortunately I have to show you guys how SSSSLLLLLOOOOOOWWWWW my progress on this project is going. I read somewhere a furniture maker said "If it has more than one curve than I'm not going to make any money." Oh My God was he right. I started the templates for the crib on 6/19/2004, so I am about 6 weeks in. By far this is the slowest project I have ever done.
So to start I did all of the mortising a couple of weeks ago, I had to do a total (by hand) of 84. Did another 16 with a router. Used these too to get the pic below. Only showing 1/2 of the boards that were chopped up.
Loose tenons attach the posts to the rails.
This is the dry fit of the second side before I start sanding.... you can see the first side all clamped up in the background. Sanding was murder.
I left the joints extra big so that after the glue up I can plane, scrape, and sand to the final shape.
By far the hardest part of this design is the curved mortise and tenon joints. I used a router with a pattern bit to make the shoulders but it sill takes a lot of work to make them good. The picture makes it look better than it really is... There are small gaps, fortunately it is on the bottom of the rail so it will not really be visible unless you are lying on the floor looking up.
Finally, because of all the curves there is no place to put the clamps, I made some blocks that clamp to the curves to give the pipe clamps something to grab onto without denting the curves.
It is coming together, although much slower than I anticipated. Good thing she is not due until January!!!!
By bruffc
quote:Ryan - I'm expecting some pictures of your crib progress over the weekend.
