Man, need to check in more often. There were many, many others who posted the red line suggestion before I ever did, I just liked it so much I used a little Photoshop to make my signature.
BT3100 setup
This is a sticky topic.
Here's the original that you're looking for
Welcome stuartjs,
Congratulations on the acquisition of your BT3100 Table Saw and welcome to the "family".
One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the one before it, so you MUST keep them in sequence.
A good one will cost you quite a bit of money, $40 - $75, or more.
I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30 -60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner. That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60, if possible.
Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate.
Regardless of what you've read or others have told you, NEVER NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes.
The reason is simple, most of them contain Silicones and they will make your projects difficult, if not impossible, to finish.
entire saw.
Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top.
You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/articles/
The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site).
One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM. Performing this PM on a monthly basis would be a good idea.
One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
It's a line that extends the line-of-sight from the saw blade to the front edge of the table to remind you NOT to let your Miter Fence or your FINGERS get in the way of the saw blade. Just put red paint, nail polish, or what ever, in the groove that extends towards the operator from the front edge of the saw blade.Stop thinking why you can't and Start thinking how you CAN!
GeorgeComment
We seem to have a small resurgence of new owners of late. It reminds me of how much this forum has changed over the years and how much it has remained the same. I am further reminded of some of the folks that simply are no longer with us like Gmack5 above and Monte; two of the finest members that have passed from this world.
I am moving this thread to the "Best of Forum" and sticking it in memory of George. May his sole rest in peace!Last edited by Black wallnut; 01-27-2011, 08:11 PM.Donate to my Tour de Cure
Thanks for the credit. I most certainly did "join the club"--that was what gave me the idea for the thin red line in the beginning; in fact, I have to confess I've joined more than onceNot quite. Norm in Fujino generally gets the credit for being the first to post a picture of the red line and also the first to post what it is, but this was over on the old Ryobi forum. However I had independently came up with the same idea, only mine is yellow as that was the color of paint pen I had. I did not have a camera at the time so could not post pictures. Furthermore IIRC I "joined the club" before I painted my line, I'm not sure if Norm ever did "join."
I may have also been the first (or one of) to voice the idea of installing shim supports to prevent that inevitable failure (back in the day when it was necessary). SOW, I finally did a break-down and cleanout of my BT3000 just yesterday since it had been acting a bit tight; lots of gunk on the shim sliding surface, but after cleaning it's smooth as butter once again. I've been using it intermittently but rather roughly this year since I'm in the middle of replacing the siding and all trim on my house.==========
Green Gables: A Contemplative Companion to Fujino TownshipComment
