HF Jointer modification for dust collection?
  • DaveinFloweryBranchGA
    • Oct 2004
    • 361
    • Flowery Branch, Georgia, USA.
    Has anyone modified their HF 6" jointer to facilitate dust collection? If so, would you be kind enough to post what you did and perhaps pictures?
    I'm getting a lot more serious about dust collection lately and while I'm replacing this jointer for a larger one in the future, I want to have effective dust collection for it while I have it and for the friend of mine whose going to get it from me when I upgrade.
    Thanks,
    Dave
    Dave in Flowery Branch, GA
    On the to do list. I picked up a collector plate from Rockler when I went down to see Rod. I was looking at it last night when I finished changing the casters on the mobile base. My thinking is to glue the collector plate to a piece of 1/8" ABS and drill that to bolt over the stock ejection chute with the collector fitting as low as possible.
      Dave,
      I took this pic on the way out the door this morning. HTH.
      I got a piece of sheet steel at BORG and mated it with the "jointer hood" from the HF DC accy. kit. Left the stock chute in place and just slipped this between the chute and the panel.
      I put a little caulk in there just to keep the air flowing where it's supposed to. Probably overkill.
        • Oct 2004
        • 361
        JR,
        You did just what I finished doing, except I used a piece of 1/8" plywood I had in the shop. Thing was a bear to get apart and back together. It helped some, but I'm seeing this jointer has plenty of "holes" where the air can leak or allow the sawdust to escape. I think I'm going to try some HVAC ducting tape and see if I can get most of the air leaks sealed up.
        It would appear getting decent dust collection for the HF 6" jointer may be a bit of a challenge.
        Dave
          Had some shop time today after I mounted the new casters under the BS and put this togther. Same idea but I bolted it to the ouside on the jointer rather than try to take the thing apart. The notch to the upper right saw needed to clear the retainer clip. The 'V' notch on the left was in the scrap piece I used.
          Backing plate was made from 1/8" ABS and fitted to the ejection chute.
          I trimmed a Delta Jointer Dust Fitting to avoid the blots and glued it in place. 4 pop rivets were added to hold it in place in case the PVC glue didn't work.
          Better than an open chute but still a lot of places for chips to escape.
