I needed a hammer drill as I was reorganizing my garage and needed to drill lots of holes in cinder block walls. I went to Harbor Freight and found two models, a regular hammer drill for $25 and an SDS rotary drill (Item #2957) for $35. Naturally, I picked the SDS drill. I get it home and can't move the switch to select between drill mode, drill+hammer mode, and just hammer mode. I manage to force it with a pair of pliers to drill+hammer mode and was pretty happy with the performance for the weekend. Today I exchanged it for another, I verified the switch moved in the store and brought it home. The switch moves fine but doesn't appear to change the motion of the drill- i.e. if I stick in a chisel bit and put it in hammer mode, the chisel appears to just spin, not hammer. Think I just have another bad unit or is this a common problem for this drill? Now that I've used it a bit, I really like the SDS chuck and bits- so easy to change and you know they are secure. Anyone else have this drill and can confirm their mode selection switch works?
Trouble with SDS Drill
Tags: None
Many of their items are junk. However, there are a few items worth buying. If you are happy with the performance of the SDS drill, just return it again for another one until you get one that works 100%. I will admit that HF CS is excellent.
________
Live SexLast edited by newbie2wood; 09-15-2011, 04:31 AM. -
Yeah it appears this drill is just plain junk. Tried 3 different ones out, 2 of them worked fine in the store but the switch was a bit difficult to move. Put some channel locks on the switch to try and loosen it up, and that seems to render it useless. The switch moves fine but doesn't actually switch modes. This third one is going back for good.
I have seen some drills where the switch has to be moved while the drill is running. had one at work that was that way. Did you try that?John HunterComment
I went to HF once. It looks like most everything in there is junk. And some of the prices were so low it was scary. I know you get what you pay for so I left. Im all about good deals but to compare something that normally runs for say $250 and HF has it for 16.99 Im thinking its probly not much of a deal. Arent most hammer drills pretty dang expensive? like 1-2 hundred bucks based on power chuck etc?YOU DONT HAVE TO TRAIN TO BE MISERABLE. YOU HAVE TO TRAIN TO ENDURE MISERY.Comment
I have bosch hammer drill that you either need to switch it while it is running or hand turn the chuck while moving the switch so that it falls into place.
When using it in drill mode or hammer drill mode, you can not tell the difference until you put a load on it. Just holding it up, pressing the trigger and watching it spin will look and sound like it is in drill mode regardless of which mode it is actually in.
I don't know if all are like that but that is how mine works.JamesComment
James is correct. You can't tell the difference between hammer mode and regular drilling unless you are actually drilling something and you can hear the hammer action.
As for HF tool prices, I believe that HF can sell the tools that cheaply because manufactures for the most part don't have advertising budgets, and because they use old dies, etc they buy from other manufacturers cheap. So you get a tool that is probably using older technology and certainly has a lot looser tolerances on all the parts. So you end up bringing it back 2 or 3 times to find one that works.David
Yeah I'm talking about going from Hammer-only mode to hammer+drill mode, it stays in hammer mode except the switch is pointing to hammer+drill mode. I tried moving it with the drill running, same thing. This third unit is going back today and I'll pickup their traditional hammer drill instead.
