My fence handle would go all the way down and then was not great. It would not engage the rod to clamp the rear of the fence. Here is my solution:
- The Plate was broken and missing.
- I inserted a piece of sturdy plastic from the rod to the Clamper.
- Another piece of the same plastic holds it in place. It is not very tight but it doesn't fall out because of the pressure from the Rod and the horizontal piece that is attached with the two screws.
The plastic is from a roll of plastic I had laying around. It is about 3mm thick and pretty stiff. Almost any relatively thick plastic that is pretty stiff would work.
This makes everything work as it should. The fence now clamps tight front and rear and the handle is tight at the level of the rail.
