Delta 35-7646 10 Inch 60T Crosscut Circular Saw Blade $29.99
  • hophop
    • Aug 2009
    • 59
    I just ordered one. They charge $6.00 for shipping, each blade
    http://www.tooliday.com/?utm_source=...m_medium=email
    • 22023
    if you are interested in this for a clean cutting crosscut blade take a close look at the Freud Avanti TK806 80 tooth thin kerf, 10° hook angle, 10" crosscut blade on clearance at Rockler for $29.99 - Rockler has had free shipping the last 5 or 6 weeks with a weekly code.
    http://www.rockler.com/product.cfm?p...freud%20avanti
    I don't know about the Delta blade but the Freud is reasonably well regarded and has a few more teeth; all other things being equal it should give a smoother cut. and will maybe save you shipping. free shipping code changes every week, use V0749, try V0750, V0751 etc. if that doesn't work.
    I have had one on my CMS for a few years and its nice, I recently bought another on this deal from Rockler - i think its about a wash price-wise with sharpenening the old one.
    • hophop
      • Aug 2009
      • 59
      Thanks Loring. I'll buy one more, and put the lesser one in my chop saw.
      • Knottscott
        • 3815
        • Rochester, NY.
        • 2008 Shop Fox W1677
        I like Loring's suggestion, depending on your application. A couple of things to consider...the 35-7646 is a full kerf blade (0.118" IIRC), whereas the TK806 is thin kerf. I've used the former version of the 7646 when it carried a DeWalt DW7646 series 60 moniker. It's a well made blade and performs well if a full kerf 60T blade with a 10° hook suits the need. It labored my tablesaw a bit if I ripped anything over 1", but it crosscut well and should be fine for a CMS, but not a great choice for a SCMS or RAS.
        Also, there are two versions of the TK806...one is an ATB (bordering a Hi-ATB), and the other is a triple chip (TCG) known as the TK806"L". The ATB is the cleaner cutting of the two, but the TCG is the more durable.
        • phrog
          • Jul 2005
          • 1796
          • Chattanooga, TN, USA.
          if you are interested in this take a close look at the Freud Avanti TK806 80 tooth 10" crosscut blade on clearance at Rockler for $29.99 - Rockler has had free shipping the last 5 or 6 weeks with a weekly code.
          I have that Freud blade and it is a very good one.
          Richard
            • 22023
            the rockler closeout is apparently the ATB version. Rockler says ATB, the blade actually says HiATB. The hook angle measures at 10 degrees.
            • hophop
              • Aug 2009
              • 59
              I ordered the Delta 35-7670 blade for a total of $35.99. They, ToolKing, sent me the Delta 8'' Stacked Dado Set 35-7670 and charged me a total of $55.99. Now what do I do?
                • 22023
                well a quick search of the web shows the Delta 35-7646 is the 60T 10" blade
                and the 35-7670 is the 8" Dado
                1. if you ordered a 7670 then that's what you got.
                2. if you ordered a 7646 then they sent you the wrong item.
                3. If their ad called the 7646 a 7670 then they made a mistake, too if you ordered a 7670 thinking it was a 7646.
                The best thing to do is call them and explain what you wanted and what you got and see what they'll do. If its 2 or 3 then they should prepay the return shipping and send you the blade you want at their cost and refund the difference.
                if its 1 and you intended to order a 7646 but accidentally ordered a 7670 then you can throw yourself on their mercy and see if they'll trade...and refund the difference, but you may have to eat the return shipping cost.
                I think those are the fair outcomes for the 3 scenarios i listed.
                • bing!
                  • Apr 2010
                  • 33
                  Whoop, whoop! I ordered the Freud cross cut thin kerf blade. Thanks for the link!
                  /bing
                    According to another forum, it sounds like multiple people received the dado set instead. Either they misposted what was for sale, or someone in shipping really screwed up.
                    • hophop
                      • Aug 2009
                      • 59
                      I mistyped it in my earlier post.
                      It was #2 with a slight variation..
                      I ordered the blade with the correct part number, 35-7646, as the first post indicated, but they sent me the Dado set instead. Since I also ordered the Freud blade from Loring's link afterward, I don't need their blade. Now, the dado set costs me a little more ($16). Amazon and other places sell it for a little over $150. I normally would not pay that much for dado set. Do you all think I get a relatively good deal for the Delta dado set at 55.99 including shipping?
                      By the way, I tested the Freud blade on a piece of 1x6 pine, and the cut surface feels smoother than sanding. Amazing... for 30 bucks.
                        • 22023
                        not familiar with the Dado from Delta.
                        But for $150 you would expect a nice one.
                        Another question is, do you have a BT3x saw? If so there's issues with 8" dados, the BT3x is probably better with a 6" set.
                        If you have a normal 10" contractor saw and you need a dado, then you might take a risk on the Delta one for $55 or whatever.
                        If you have a BT3x family saw, then you would probably be happier in the long run with a 6" dado.
                        I know that Freud makes nice 6" and 8" stack dados.
