Results 1 to 6 of 6
Thread: Staining wood before or after glue-up???
  1. Staining wood before or after glue-up???
    I'm back for more help!! I'm making some cabinets for the kitchen, and I've cut the stiles & rails for the doors and face frames to length as well as the drawer fronts. My question... is it better to stain the pieces before you put them together or glue them up first and stain when they are put together? Any help or suggestions would be appreciated.
    Thanks
    Geo
  2. #2
    Join Date
    Jun 2006
    Location
    So. Florida
    Posts
    15,217
    Generally speaking I stain after assembly. Any imperfections from assembly can then be dealt with prior to stain.
  3. #3
    Join Date
    Jan 2007
    Location
    Winchester, Ca
    Posts
    1,554
    While I don't stain the doors I make I glue up before using Danish Oil and applying final finish. I would think that cleaning up any glue from pre-stained parts would/could be a royal pain and create additional work, et al, sanding, restaining, etc. I vote with C-Man, glue up first.
    RAGS
    Raggy and Me in San Felipe
  4. #4
    Join Date
    Dec 2002
    Location
    Fujino-machi, Kanagawa-ken, Japan.
    Posts
    533
    I do partial stain before glueup, in some cases to prevent white wood showing in event of expansion. In other cases, I do a partial local stain of small difficult-to-access areas since any remaining glue will resist later stain, and it's sometimes very difficult to remove glue later. I then do a full stain after glueup.
    Against the chance of wood movement showing white:
    To prevent getting stain on the ebony sections, and to assure stain is absorbed on the inside surfaces of the stretchers between the spindles:
  5. #5
    Join Date
    Apr 2005
    Location
    Mountain Lakes, New Jersey, USA.
    Posts
    314
    I find that glue does not adhere well to a stained surface. So I glue up before I stain. If you choose to stain before glue up then try to keep the stain off of the glue up area.
  6. #6
    Join Date
    Mar 2007
    Location
    Garden Grove, CA
    Posts
    91
    Quote Originally Posted by Uncle Hook View Post
    Generally agree with the above except for raised panels. If you stain them after assembly and the wood moves on the floating portion, you will see unstained edges. Since they aren't glued in place, stain the raised panel first before assembling.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
