Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Does crown molding have a top and bottom?
  1. #1
    Join Date
    Aug 2003
    Location
    Maryland, USA.
    Posts
    3,029
    I'm about to install this crown molding from Wall Lumber.
    My wife actually prefers it with the bulge on the bottom rather than on top
    like in the picture. Is there a practical or aesthetic reason to install it as
    shown or should I just listen to her?
    Thanks,
    Paul
  2. #2
    Join Date
    Jun 2004
    Location
    West Central Ohio
    Posts
    1,912
    Quote Originally Posted by atgcpaul View Post
    ... My wife actually prefers it with the bulge on the bottom rather than on top like in the picture. Is there a practical or aesthetic reason to install it as shown ...
    No clue
    ... should I just listen to her? ...
    If she is like my wife YES!!
    Personally I would install it how I (we) want it to look. We have to put up with seeing it everyday.
    Edit: After taking a double look at the picture, would there be a valley / dust trap / bug trap /etc if turned upside down.
    Ric
  3. #3
    Join Date
    Jan 2008
    Location
    Pennsylvania
    Posts
    146
    The way you are showing the picture is correct. I have installed this in many homes and it is always like you are showing. Just remember whe you are cutting the miters for the corners, it is always upside down and backwards for it to fit properly.
    That being said, if she wants it the other way, go for it.
    "The power of kindness is immense. It is nothing less, really, than the power to change the world."
  4. #4
    Join Date
    Jun 2006
    Location
    So. Florida
    Posts
    15,217
    Usually, the small detail is the bottom of the moulding.
  5. #5
    Yes, the angles on the edge of crown molding are 52 and 38 deg.* Normally the crown molding extends further onto the ceiling than down the wall. If you need to mount it with the top side down and wish to maintain the same aspect ratio then you could re-cut the edges.
    Now, does you wife really want it that way or did you just ask, "Witch way do you like it dear?" and she made the decision without really having a preference. The purpose of the molding is to hide what was typically a bad joint at the top of the wall, think post and beam, lath and plaster, seasonal movement and no fiberglass reinforced tape. The busy part or detail edge takes the eye and focuses your view on the wall and off of the ceiling. Walls have things you want to be looked at and ceilings have cracks, think walking on the floor above and lath and plaster.....
    In today's house you should have none of the problems that early builders had but, do you really want people looking at the ceiling and tripping over the cat rather than at your wife's artwork on the wall?
    Bill, who thinks that having started second guessing his wife there is no hope left for Paul.
    * I am sure there is stuff out there with different angles, this is just what I am used to.
  6. #6
    Join Date
    May 2005
    Location
    Paso Robles, Calif, USA.
    Posts
    2,878
    Another reason not to install it upside down is the profile was designed with its "shadow lines" to look a certain way when installed correctly. When it is upside down it will not look correct.
  7. #7
    Join Date
    Mar 2007
    Location
    Sacramento, CA
    Posts
    426
    Another concern would be when you go to sell the house - if someone notices that (I would) it would be another thing that needs to be fixed and would probably cut into your sale price. It might make people think "what else wasn't done right".
  8. #8
    Join Date
    Dec 2007
    Location
    Indianapolis, IN
    Posts
    946
    Quote Originally Posted by Tom Slick View Post
    My thoughts also upon reading this. It will throw off the shadow lines and create a trap for flying dust bunnies.
  9. #9
    Join Date
    Jan 2003
    Location
    Mebane, NC, USA.
    Posts
    10,624
    Paul,
    Not listening to your wife is gonna get you into trouble. Funny you should ask this now though.One of my brothers is a part-time handyman. Two weeks ago he installed the trim in a house for a contractor after a guy got sick. HeThe client insisted the crown be installed like your wife wife wants. He told me about it then and we agreed it would look terrible. My brother called last night to tell me he is being called back to pull the crown and turn it over.
  10. #10
    Join Date
    Jun 2006
    Location
    So. Florida
    Posts
    15,217
    Quote Originally Posted by crokett View Post
    Paul,
    If he's going to try to reuse what's up...longer pieces can be cut shorter, but...
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
