Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Quikrete 'Concrete Mix' vs 'Fast Setting Concrete Mix'
  1. #1
    I will be pouring some deck footers using the pre-formed tubes. It appears there are two types of concrete that may be used. One is fast-setting and the other is not. What are the pros/cons of each type? I won't be putting the deck on it for a few weeks after it is poured... so the fast setting isn't really a requirement for me from that standpoint.
    Quikrete
    QUIKRETE® Fast-Setting Concrete is the ideal concrete mix for this job. It gains its initial set in 20-40 minutes and reaches strength of 1000 psi (6.9MPa) in 1 day so construction work can continue almost uninterrupted. QUIKRETE® Concrete Mix is another excellent mix for constructing QUIK-TUBE™ footers.
  2. #2
    Join Date
    May 2004
    Location
    Off The Back
    Posts
    6,685
    I've only used the regular stuff. According to the spec sheets, both reach a compressive strength of 4000psi in the standard 28-day curing period, but the write-ups make it sound like the fast-setting flavor is intended more for filling in around fence posts, and for light-duty slabs, than for footings. The "pour dry mix into hole, then add water" part seems to reinforce this.
    Since you say time isn't a factor, I'd recommend you use the regular.
    Definitely what Larry said.
    The fast-setting stuff has gravel in it already. It's specifically designed for post-hole applications and tends to have grainy, chunky consistency that can break down over time.
    For deck footings you'd be better of with regular Quik-Crete mixed to your satisfaction.
    That quick set stuff is good for mailbox posts. I would use regular mix for doing footings though.
  5. #5
    Join Date
    Jan 2004
    Location
    Nazareth, PA, USA.
    Posts
    330
    The quick setting stuff costs a bit more than the regular as well, I want to say almost double. I think I paid $4 a bag 3 months ago when I poured my deck footing, and the quick dry stuff was around $7. I needed 30 bags so there was really no choice.
    But the fellas are right, that stuff is only good for mailbox posts and the such.
    Happy pouring.
    Join Date
    Dec 2005
    Location
    Wayne, NJ, USA.
    Posts
    1,566
    I believe most recent Fine Homebuilding has an article on deck footer pouring. Including determining proper thickness/depth and type given the site, deck size, etc. Number of bags calculation and full description of the process, too.
  7. #7
    The thing with the fast drying concrete is it cures fast which makes it harder to work with. Anyone who works around concrete knows slowing the curing process helps prevent cracking. If you are mixing say 6 bags per footer, you will have to mix like a mad man or it will start to setup before you get the next bags mixed.
  8. #8
    thanks.... everybody confirmed my suspicions. I will go the regular route!
    The slower cure should give me more time to pour all my (4) footers (~28 bags) then go back, check my alignment... and do the J bolts in the end. right?
  9. #9
    Quote Originally Posted by PALefty
    Any thoughts on this? Would it be better to set each J bolt as I go along... or do I have time to do it at the end (using standard Concrete Mix)?
  10. #10
    Join Date
    Feb 2003
    Location
    Lexington, SC.
    Posts
    4,054
    Depends some on the ambient temperature and humidity. I would probably put the J bolts in and check the alignment at the end and hope I could move them. If you cannot and they are too far off, you can cut them off with a recipricating saw and drill a hole for an anchor (lead is tradition but there are others).
    If you want your footings extra strong, you can also buy a bag or two of portland cement and add a little to each bag of pre-mix as you mix. It does not take a lot of extra cement to up the strength. Probably overkill, however.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
