Results 1 to 9 of 9
Thread: Ridgid Drill Stuck Chuck!!!
  1. #1
    stioffan Guest
    How do I fix my Ridgid Drill Keyless Chuck that is stuck in a Wide Open position? It does not want to close for anything.
  2. #2
    Join Date
    May 2005
    Location
    Paso Robles, Calif, USA.
    Posts
    2,879
    what if you use 2 sets of pilers in opposite directions. maybe some penetrating oil will help too.
    if you can't get it loose a new one is only $30. they are a universal part.
  3. #3
    Join Date
    Aug 2005
    Location
    Washington, NC USA
    Posts
    656
    I would get in touch with Ridgid before you go buying anything, especially if it is under warranty.
  4. #4
    Join Date
    Feb 2003
    Location
    Santa Clarita, CA, USA.
    Posts
    49
    I once had the same problem with an electric drill and it was the screw inside the chuck that attaches it to the shaft that had loosened up and all I had to do was tighten it and all was well. If I rememer correctly the screw was a left hand thread. Could this be your problem?
    Palermo Len
  5. #5
    stioffan Guest
    I have tried the two pliers trick............to no avail. Thanks Tom
  6. #6
    Join Date
    Dec 2005
    Location
    Philadelphia (actually Souderton), PA.
    Posts
    303
    two pipe wrenches ought to break it loose. Just go easy.
    I like Wagoneers too. Hey...they've got wood
  7. #7
    Join Date
    May 2005
    Location
    Posts
    2,879
    I've had to destroy them to get them apart in the past. if it's stuck really well then it's replacement time.
  8. #8
    stioffan Guest
    Thanks everyone for the help. I also used a pair of pipe wrenches. Your right Tom, it looks as if a replacement is needed.
    Thanks Again
  9. #9
    Join Date
    May 2005
    Location
    Posts
    2,879
    keep in mind that the screw in the center is left-hand thread, the chuck will be normal right-hand thread though.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
