Error updating the profile
  • jarhead
    • 695
    • Boynton Beach, FL.
    I am trying to change my "Where you live" location and getting this error message.
    • 3119
    Date of birth is one of the fields that cannot normally be changed on the site. Send me a PM with what you want it changed to, and I can make the change for you as an administrator.
    • Black walnut
      • Aug 2015
      • 5514
      The problem is most likely when you first registered you did not enter a valid date of birth. It may have been a voluntary field. As such you will need to submit your actual date of birth to twistol or myself and we can change that field. We can set the birthdate privacy to whatever you want. If you want it to be unpublished we can do that. We need it to comply with COPPA laws. After that you should be able to edit your user cp. If you add in the email to one of us your current city/state/ or country we can edit that as well for you, but first we need to edit the DOB.
      • d_meister
        • Feb 2009
        • 258
        • La Conner, WA.
        I just tried again to change the avatar from the default previously selected California flag to my new home state flag of Washington, following the "use a default avatar" prompts, and it was again unresponsive. After selecting the flag from the default list, there was no further action possible except "cancel". "Continue" was unresponsive.
          • 3119
          Default avatars went away in one of the releases of vBulletin, but they didn't get all the code so they still shows up as an option, but there is no option to remove the old configuration.
          If you want to use one of the state flags, right click on it and copy the image link or image address and paste that into the avatar URL in the "Copy and paste an image URL from a hosting site." option.
          • d_meister
            • Feb 2009
            • 258
            • La Conner, WA.
            Thank you for the response. I was just being lazy and doing the path of least resistance for avatar selection. Having the flag is actually redundant, as my location is listed, anyway. Now I'll have to focus and make a selection and the right size image.
