Shark Guard dumb question. How to change ports?
    • 9221
    I had ordered the whatever generation it was SG and additional port, so I have both the 4" and 2.5" ports for the SG. In my cleanup / rearrangement of the shop I found the 4" port in my DC spares. I want to run the big port on it instead of the little one.
    It's been years so I just wanted to double check. Do I simply take the side plate off, and slide out / in the port panel and then put the side plate back on?
    I could be wrong, but I am figuring especially with the upgrade to 5", the blade guard is REALLY where I want the dust to be picked up from more so than the bottom of the saw...
    • 2900
    Basically, yes, you remove the screws around the dust port and slide it out the back.
    Documentation Here
    If your version is different, give them a call. I've had nothing but superior service from them.
      • 9221
      Nope, that's the right model. Thanks for the link. Done deal!
