Drill press laser guide by peachtree
  • Sweet Willy
    • May 2011
    • 195
    • Near Chattanooga, TN
    • ridgid 3650
    I mounted one of these to my drill press today. Like all the reviews I read it was a PITA to line up the lasers but once it was done it works really well. My only complaint so far is the laser lines are too wide so the sweet spot takes a little getting used to. Otherwise, sweet.
    Dennis
    Sweet Willy
    sigpic
  • tfischer
    • 2349
    This has been on my "would like to have" list for some time. Seems silly they can't use a sharper line though... the whole point of the thing is to drill accurate holes and if the line is basically a crayon width that isn't going to happen
      • 22109
      sometimes on those different kinds of lasers the lines are very bright to accommodate all kinds of ambient lighting. Its possible that your shop lighting is dim, the lines are so bright it makes it the lines shine so much that its hard to see the workpiece. Likewise very bright lines are also going to appear wider.
      You might try either increasing the brightness of your shop lighting or dimming the laser lines by using some darker filters.
      I've had a few DP lasers and one of them drew a X which usually intersected well with the horizontal/vertical lines I would draw.
      My present laser has one horizontal line and the other at 45 degrees. The horizontal line, when I line up work, either obscures the horizontal line or the horizontal line I drew is thick and dark enough to lower the reflection of the laser line so that its hard to see.
      I really prefer the X pattern for that reason.
      • Sweet Willy
        • May 2011
        • 195
        • ridgid 3650
        Yup, that's how mine works with the X. You have to line the first laser vertically and at the 45 and then the second laser at the 45. It aint perfect, but as I've said elsewhere, my 70 year old eyes aint what they used to be and the laser X makes it easier to see the dot where I want to drill.
        And you're right TFISCHER, the laser on the mitre saw is very narrow and defined, can't understand why that's not possible for the DP.
        Dennis
        Sweet Willy
        sigpic
