Okay yeah, it's the Harbor Freight cheapie. The reviews on it are astonishlingly good, and admittedly it was the demonstrator model in the store, it has surprisingly good fit and finish. Not spit and polish or anything, but certainly good castings, trimmed clean, assembled neatly. Even the stickers were nicely aligned.
I know there will be some initial setup to deal with, but once that is done, I should be ready to go...
Now this IS a slider, which means, it is a BIG saw. It's not super heavy, but then again, it's no lightweight either... But it does take up some space. My plan was, and is to modify my current back wall workbench and convert it in to a miter saw station. Simply put I am thinking about bobbing the top so that the bottom is still fully one single rail front and back, but there will be a box built on top of each side of the base. I need to measure the new saw side to side, and of course the height to the table, but I know it is 28" from the front of the saw casting not including the table, to the back of the slide rails with the saw FULLY slid backwards. I intend on mounting the saw on a 30" deep shelf. Now this is where the problem occours. The lip that the current bench sits is 24" deep, and 1.5 to 2" high (I don't recall off hand, but I am thinking the height of a 2x4 on its side... I can either extend the top cantilevered to gain the additional 6", OR I can extend the entire frame out 6". (Which I would prefer. I would need to extend the front legs the height of the lip at that point. Which is fine. Purpose built and all...
The other option is to build a portable miter saw station... The kind of thing I can plop on to sawhorses. But I am thinking that is a bad idea back wise...
