I just replaced the pressure switch on my air compressor. I have a very small leak at one of the fittings (about 2psi per hour).
Is there any way to seal the leak by applying a sealant to the fitting without removing it?
It was a PITA to replace this switch, and I would like to avoid removing it again to get to the fitting. I'm also concerned that if I keep removing and reinstalling the switch, I'm going to crack the plastic housing that is connected to the fitting or cause a more significant leak elsewhere.
________
HotCummers
________
HotCummers
