New kit by Wynn for HF DC
  • Nick Keenan
    • Apr 2004
    • 457
    • washington, dc, USA.
    I hadn't seen anyone posting here about this, and I think it might be of interest. Wynn Environmental has introduced a new filter that is a drop-in replacement for the Harbor Freight dust collector -- no more cutting a donut out of MDF. It comes as a kit with everything you need to do the conversion, including plastic lower bags.
    See:
    http://www.wynnenv.com/35A_series_cartridge_kit.htm
    It comes in two versions: a paper filter kit is $82.00, and a washable polyester filter kit is $118.00.
    Nick
  • gerti
    • 2233
    • Minnetonka, MN, USA.
    • BT3100 "Frankensaw"
    Also great price for the bags! 4 mil, 10 for $10!
    Gerd
    • silverfox
      • 2863
      • Richland Center WI, USA.
      It sure IS of interest, Nick...I paid a LOT more than that for my JET filter a year ago. I do like the flapper on the JET though for easily knocking out the dust caught in the filter baffles. Glad to see Wynn take notice of this DC market...it will save people some money when they convert. And Gerd's right...good price on the bags too. Thanks for the heads up.
      • jarhead
        • 695
        • Boynton Beach, FL.
        I bought the washable kit and additional 10 bags. The filter is great, but the bags are a bit too small in diameter and are a PITA to put on. They will not stay on unless they are really stretched and held in place with a band that came with the original bags.
        • BizCoach
          • 93
          • Milford, CT.
          quote:Originally posted by jarhead
          I bought the washable kit and additional 10 bags. The filter is great...
          Did you install a neutral vane? I'm hoping to upgrade mine to the cartrigde but don't want to bother installing the vane if I don't have to.
          www.CEOBootCamp.com
          Tools to help you run your business better
            • 22109
            The purpose of the vane is to separate the bigger chips and stuff and keep them in the lower bag and not let them jam up in the top.
            The fine dust also gets up in the pleated filter but its easier to knock that down than the chips which tend to jam in the pleats.
            • jarhead
              • 695
              Didn't get around to it yet, but eventually will.
              • BizCoach
                • 93
                • Milford, CT.
                And it works fine without the vane?
                www.CEOBootCamp.com
                • jarhead
                  • 695
                  I don't know yet since I haven't done any extensive cutting other than building jigs (before buying the DC). I am a newbie who is in the process of setting up a shop. I am sure more seasoned WW will be able to answer your question.
                  • silverfox
                    • 2863
                    I have a 2hp HF DC with the JET canister and a pre-sep. I have no neutral vane.
                    • stewchi
                      • Apr 2003
                      • 339
                      • Chattanooga, TN.
                      Mike doesn’t need the neutral vane, he has a cool flapper.
                      I got mine installed last week, it was a perfect excuse to buy a rivoter. I spent an evening after work cutting metal until I got a good shape that fit snug. It was not that difficult. Making the donut for the conversion took much longer but that was only because I had to build a circle cutting jig for my router, once I made that it was a snap. In fact a was so proud of my donut I made a second much smaller one that fit on the outside of the BT dust port so I could plug 4” PVC into the back of the DC. Donut is 4” OD 2.5” ID. (I used hole saw bits and my drill for that one.)
                      • dlminehart
                        • 1829
                        • San Jose, CA, USA.
                        A "cool flapper"? As in, a hot babe from the '20s Jazz Era? "Good shape that fit snug"? I won't go there!
                        - David
                        • doctordremel
                          • Apr 2004
                          • 81
                          • Greensboro, NC.
                          I have the HF and not yet assembled it and am considering getting one of these right from the start, I saw the Jet with the "twisty-scrubbie thingie" to knock the fines off of the cartridge. I was wondering about putting the original HF 30 micron bag on the INSIDE somehow and maybe the fines would slough off as the bag collapsed at end of cycle.
                          \"Art is skill, that is the first meaning of the word.\"
                          Eric Gill
                          • DaveS
                            • 596
                            • Minneapolis,MN
                            I think that would defeat the purpose of the extra filter area - also, the bags will clog quickly and you will have a tough time cleaning them all wedged up into the filter like that.
                            I don't think the dust is really the biggest problem. After ripping a sheet of MDF into 8" strips, I checked the filter. Before I removed it, I banged it a bit with a broom, then hit it with a few blasts of air from the compressor. I took it off and bounced it on the floor a few times and only a little dust came out (less than a teaspoon maybe). However, there were a few larger pieces (from some cedar I had routed earlier) jammed in the folds - I never could get them loose "externally". I think a piece of window screen in there would do more for ease of cleaning than the filter bag. This was before I made my neutral vane - I'm anxious to see if it makes any difference... hopefully I'll get some shop time in this weekend.
                            • MPod
                              • 169
                              • Lenexa, KS, USA.
                              I'm a little confused about the sheet metal slug. What is it and where is it glued? I can't tell from their site whether it is the top enclosure for the filter or a donut that glues into the bottom of the filter to which the turnbuckles attach.
                              I'm also curious to know which of the two filter options you all like better. The paper is not washable but has more filter area, is cheaper, and has a lower micron rating. I worry about the longevity of a paper filter taking regular doses of compressed air. I like the idea of having something washable but the washable filter has a much smaller surface area and higher micron rating. In reality I'd want something I can hit with a blast of air and be done with it. I don't want to have to take it apart to clean everytime I finish a mdf cutting session in the basement. Them flappers are starting to sound pretty good.
                              -Mod
                              Measure with a micrometer, mark it with a crayon, cut it with an axe.
