I have an inexpensive walk-behind lawn mower with a B&S engine on it that I'm trying to keep alive... I'd rather buy a part or two than replace the whole thing.
I push the little red bulb to prime the carburetor, and pull-start it, and it runs for about a second then stops -- as if it's not sucking in any new gas. I can keep it puttering along if I keep pressing the primer bulb, so I don't think it's the gas or the engine. I'm guessing it's the carburetor or the gasket, but I wanted to get another opinion before I go buy a non-returnable part.
Anything else that I should investigate or try first?
Cheapskate that I am, I'm considering the gasket alone for $3, or the whole carburetor assembly for $20, or at last resort a new mower for $140 (which I'd have to buy just for the engine because the $140 mowers only side discharge).
The air filter looks good -- same problem with the air filter off. Fuel filter (little mesh screen, I think) looks good, too. I can blow air through the holes in the gas cap, too, so I don't think it's that.
