test
  • rickd
    • 422
    test
    this is a test
    i posted this to simply see if i could delete it! can't seem to do that. anyone know how?
    rick doyle
    Rick's Woodworking Website
    Hit the Edit button. On the next screen there is a button for Deleting.
    Ken
    • rickd
      • 422
      Originally posted by AlanJ
      Hey Ken.. how did you get your avatar to display? I've been trying to work out how to upload/add one but don't see how?
      AJ
      hi alan,
      check the following thread:
      http://www.bt3central.com/showthread.php?t=18290
      rick doyle
      • Sam Conder
        Woodworker Once More
        • 2502
        • Midway, KY
        • Delta 36-725T2
        See these two posts:
        http://www.bt3central.com/showthread.php?t=18285
        Sam Conder
        BT3Central's First Member
        • AlanJ
          • 150
          • Rochester, MN
          Thanks Ken - just saw the other thread and then came back here to delete my post - you beat me to it.
          I guess I'd better stop procrastinating and send off that check...
          AJ
          Alan
          • Stytooner
            Roll Tide RIP Lee
            • 4301
            • Robertsdale, AL, USA.
            I was wondering how something was deleted as well. This software leaves a vapor trail when something is deleted. I only usually delete spammers, and I don't think we needed a trail or remnant of that. I suppose it really doesn't matter though. It keeps better track of things this way.
            • rickd
              • 422
              i don't see a delete button
              Ken
              hi ken,
              i tried that but i don't see a delete button after i hit edit.
              i just posted a new topic and tried again to delete but after hitting edit - again, i can't see a delete button like you do.
              rick doyle
              • Sam Conder
                • 2502
                • Midway, KY
                • Delta 36-725T2
                Originally posted by rickd
                hi ken,
                At the bottom of the text box, you don't have a "Delete" button to the right of the "Go Advanced" button?
                Sam Conder
                • rickd
                  • 422
                  not on most posts
                  i just posted a new topic called 'i am going to delete this test ...' and when i hit edit there is not 'delete' button next to the 'advanced' button.
                  in this thread when i hit edit for the first post, the same thing happens - no delete button.
                  however, for my second post in this thread, when i hit edit - i DO see a delete button. strange huh??
                  rick doyle
                  • rickd
                    • 422
                    i just checked again and i do see a 'delete' button for the previous post on this thread - but not the first post in the thread.
                    i am going to try the other thread by posting a second message to see if that works.
                    rick doyle
                    • Sam Conder
                      • 2502
                      • Midway, KY
                      • Delta 36-725T2
                      I doubt the software will let you delete an entire thread, just a post. Deleting a thread, even one you started, would delete other people's posts.
                      Sam Conder
                      • rickd
                        • 422
                        i think i see what's happening here
                        hi sam,
                        i think i see what's happening - at least in my case.
                        when i make a new post and hit edit - i don't see a 'delete' option next to advanced.
                        when i reply to the first post, then edit, the 'delete' option does show.
                        not sure what that all means.
                        rick doyle
                        • rickd
                          • 422
                          o.k.
                          that makes sense - thanks. i see the 'delete' button does show up on all posts subsequent to the original. just a little different than the snitz forum method. but, this system is great a big improvement!!
                          rick doyle
                          • Sam Conder
                            • 2502
                            • Midway, KY
                            • Delta 36-725T2
                            It means what I said in the reply just above.
                            Sam Conder
